Issue with page level interactions - formula help
- 6 years ago
In that case, simply add just the logins count measure to the filter on the matrix table.
Login count measure:
Logins = CALCULATE(COUNT(User_Login[UserID]), FILTER(User_Login, [Action] = "Login"))Login measure on the matrix filter list and set to is not blank:
And a date selected on the graph that is filtering the matrix to just those users that had a login on that day:
- 6 years ago
Just to make sure I understanding correctly, you want a DISTINCT user count?
If you create a measure using the distinct count on the UserID column on the User_Login table you can actually put the AppVersion and count of users in a matrix and not require any further actions to filter.
Count of Users = CALCULATE(DISTINCTCOUNT(User_Login[UserID]), FILTER(User_Login, [Action] = "Login"))Let me know if that answers the question.
RMB what you gave me did the opposite of what I was looking for, I want to be able to click the graph and filter the userID matrix. Your solution lets me filter the graph when I click on the UserId matrix. Can you please advise how I would do the opposite? I am inclined to think this is a formula issue but I am unfamiliar with what to do
What is your axis on the graph? The above is only necessary if you're graphing with an axis from the login activity table. Do you have a sample screenshot you could share?
RMB my axis is date from a calendar table (also a shared table)
- RMB6 years ago
Resolver II
RMB that worked like a dream. Could I ask you about another one? Your help would be GREATLY appreciated.
I want to create another matrix that is filtered BY clicking the same exact graph of user login activity that looks like this:
AppVersion Count of Users 1.3 12 1.4 14 (So that when you click the bar graph, the count of users will change based on how many users logged in with that app version at that time)
I have the same 2 tables:
Logins - but this time, there is a new column with an app version id with each login instance. So the table looks like this
UserID LoginActivity Date AppVersion 1 Login 2/12/2020 1.4 1 Login 2/13/2020 1.4 2 Login 2/12/2020 1.3 I also have a users table with a unique list of userIDs
Again, my graph login count measure is from the Logins table and is Logins = CALCULATE(COUNT(User_Login[UserID]), FILTER(User_Login, [Action] = "Login"))But I need to use App version from the Logins table BUT UserID from the Users table in the matrix
Does this make sense?
