IF Statement using Power Query
- 9 years ago
Try this code:
= if [DT_SCHED] < #date(2017,6,1) then "DELIVERY DATE JUNE 1ST" else if [DT_SCHED] < #date(2017,12,31) then "DELIVERY DATE DECEMBER 1ST" else null
PQ is case sensitive and if...then...else is all lower case, just like null.
Also mind your boundaries: in your information, June 1st is undefined; in the code above it returns December 1.
Likewise, December 31, 2017 will return null, according to the specifications provided.
How can you have millions of rows in Excel? As far as I know, Excel has a maximum of 1,048,576 rows
Try this code:
I miss spoke Marcel. It's the database that has millions of queries and that's where am going in to filter by date range. You filter worked perfectly. THANK YOU, YOU GUYS ARE AWESOME!!
