IF Statement using Power Query
- 9 years ago
Try this code:
= if [DT_SCHED] < #date(2017,6,1) then "DELIVERY DATE JUNE 1ST" else if [DT_SCHED] < #date(2017,12,31) then "DELIVERY DATE DECEMBER 1ST" else null
PQ is case sensitive and if...then...else is all lower case, just like null.
Also mind your boundaries: in your information, June 1st is undefined; in the code above it returns December 1.
Likewise, December 31, 2017 will return null, according to the specifications provided.
How can you have millions of rows in Excel? As far as I know, Excel has a maximum of 1,048,576 rows
In the Query Editor try the Add Conditional Column feature
Add Column tab => Conditional Column button (then the code will be generated for you)
- dkay84_PowerBI9 years ago
The syntax for date values in Power Query is #date(year,month,day).
Thus, your if then statement would say if [Date] <= #date(2017,6,1) then ...- Phil_Seamark9 years ago
Agreed, the Syntax of your IF statement is good.
Here is a nice breakdown on the subtle differences betwen the Excel IF and the Power BI IF
http://www.excelguru.ca/blog/2014/08/27/the-if-function-in-power-query/
- marcoselias8 years ago
Advocate V
Sean,
Thanks for pointing this out. It seems like it's going to help me but how can I do an AND or an OR to combine conditions? It looks like it only accepts one rule at a time. I'm trying to do something like:
IF <condition1> AND <condition2> THEN <result> ELSE <alternate result>
I hope I don't need to resort to creating multiple conditional columns.
Marcos
- dkay84_PowerBI8 years ago
You can use AND/OR you just have to fully qualify it:
if <something> = <something> and <something> = <something else> then...- marcoselias8 years ago
Advocate V
Thanks! My question was within the Add Column > Conditional Column section but your answer helped me within the Add Column > Custom Column :)
- Nischal8 years ago
hi , when i am trying to get two conditions using and function its throwing an error
example:
if 'table'[field] = {condition1} or 'table'[field] = {condition2} then {output1} else {output2}
You can replace the "or" with "and" depending on your logic. Obviously your conditions don't have to be based on "=" either.
Also you can nest ifs:
example:
if 'table'[field] = {condition1} then if 'table'[field] = {condition2} then {output1} else {output2} else {output3}
