Human
2 years agoFrequent Visitor
Help with volume differences calculation
Hi everyone, i would like to calculate for the total differences in volume used for each variable a,b and c. Each volume difference will refer to the 'TRUE' and 'FALSE' state of each variable. The y...
CoreyP
Solution Sage
2 years agoAnd what exactly are these variables? They can just be either true or false based on a calculation or something?
Human
From my understanding, the variable is some kind of machine that utilizes the volume and the value of 'TRUE' and 'FALSE' is the status of the machine state whether it is in use or not. TRUE as in-use indicator and FALSE as when the machine is not in-use.
