Help with volume differences calculation
Can you please try to clarify? I'm not understanding at all what you're hoping to achieve. I see that 704-667 = 37, and 740 - 630 = 110 , etc. But I can't figure out for the life of me what logic you want to apply and when.
- Human2 years agoFrequent Visitor
So I'm trying to create a calculated column/dax to calculate the differences between the volume column which would be referring to the start and stop of the 'TRUE' state of variable A,B and C. So for example for variable C, for the 'TRUE' state would start at volume 630 and ended at 594. So the result I intended to be returned would be the difference between 630 and 594.
Sorry if I was not being clear. I'm quite new to Power BI.
- CoreyP2 years ago
Solution Sage
Oh, no worries. Thanks for clarifying. Is there like an end objective? There's likely a more effective way to model/structure your data to accomplish what you're looking for without writing a weird DAX column.
Thank you for your understanding. So for my end objective, I intend to be able to calculate the total volume used for each variable and eventually, the total/overall volume use.
