Anonymous's avatar
5 years ago
Help with using the MAX function in a custom column
I need to create a custom column using a DAX statement.  I'm pretty sure I need to use the MAX or MAXX function to accomplish what I'm trying to do here.
Specifically, I need the new column to return the [Members] for each [GroupID]...but only in the row where that GroupIDs [MonthEnd] date is the latest.
Here is an example of the current table:
I want to add a new column to this table called MaxMonthEnd that would return the following results for each row:
Please let me know if you need any other detail for this.  I'll be monitoring the thread closely.
Thank you!
Andrew
  • Column 2 = IF([finish]=CALCULATE(MAX('Table'[finish]),ALLEXCEPT('Table','Table'[id])),[members])
    Anonymous  can you please try the above as a calculated column
    finish = MonthEnd
    id=GroupID
  • smpa01's avatar
    smpa01
    finish = MonthEnd
    id=GroupID
  • smpa01's avatar
    smpa01
    Anonymousplease provide the sample data here in a way which can be easily copy pasted
