5 years agoNot applicable
Help with using the MAX function in a custom column
Hi, I need to create a custom column using a DAX statement. I'm pretty sure I need to use the MAX or MAXX function to accomplish what I'm trying to do here. Specifically, I need the new colu...
- 5 years ago
Column 2 = IF([finish]=CALCULATE(MAX('Table'[finish]),ALLEXCEPT('Table','Table'[id])),[members])Anonymous can you please try the above as a calculated column
finish = MonthEnd
id=GroupID
smpa01
5 years agoAnonymousplease provide the sample data here in a way which can be easily copy pasted
