W2SANC
Helper II
3 months agoHelp with Layering Reference Layer with Marker Layer (with Conditional Reference Layer Filling)
I have a geojson file of counties (includes 5 digit FIPS). a query with 5 digit FIPS that has counties and their banking desert status (either a banking desert, potential desert, or not a banking des...
- 3 months ago
Hi W2SANC,
The Azure Maps visual does not support dynamically filling GeoJSON reference layer polygons based on a field from your power bi dataset. You can either embed the fill colours directly in the GeoJSON before importing it or use a custom mapping visual if you need dynamic polygon colouring together with store location markers.
Thanks and regards,
Anjan Kumar Chippa
