palvarez83's avatar
palvarez83
7 years ago
Help with dax filter function using measures as arguments.
I was hoping someone can help me figure out my syntax problem.  I have two tables disCalendar and fCommTime which are not relate.  My disCalendar table has 3 useful columns I am trying to use to filter:
1.  disCalendar[Date] which is every date from 1/1/18 until 1 year from today.
2.  disCalendar[Workday] which is either a 1 or 0 dpending on if it is true/false
2.  disCalendar[Productivity] which is a factor can either be 1.0, 1.4, 1.6, or 1.8 depending on the date.
I would like to create a couple of measures to:
1. Find the next working day given the takes a given date from one of the fCommTime Columns and
2.  Lookup the productivity on that specific date from disCalendar
Heres what I have so far:
1.
[End date]=SUM(fCommTime[ActualEnd])
This summarizes the date in rows from the given date column and returns the correct date based on filter context.
2.
[NextWkDy]=calculate(min(dCalendar[Date]),filter(dCalendar,dCalendar[Date]> [End date] && dCalendar[Workday]=1))
This uses the filter function to filter dCalendar table to allow only dates that come after [End date] and are a working day (dCalendard[workday]]=1.  Then it returns the earliest date in that filtered table using the min(0 function.  It appears to be working fine up until then.
Now the problem.  I would like to lookup the productivty for the next work day given from the previous measure.  Here is what I tried.
[NextWkdyProd]=CALCULATE(Sum(dCalendar[Productivity]),filter(dCalendar, dCalendar[Date]=[NextWkDy]))
My problem is that instead of the filter function returning a single row for that given day like is should based on the "=" operator it is returning  a whole table starting from that date all the way until the end day and then becasue I am calculating a sum, it is giving me a really large number.  Why isn't it returning only the dates that match?
Note:
1.  I was able to make it work okay if I use calculated columns so I must be missing something
2.  I am using a sum istead of of a min, because at sum point I would like to be able to alter the code to return the sum of the productivity between 2 dates.
  • Hi palvarez83
    You may refer to below measure:
    NextWkdyProd =
        SUM ( dCalendar[Productivity] ),
        FILTER (
            dCalendar,
            dCalendar[Date]
                = MINX (
                    FILTER ( dCalendar, dCalendar[Date] > [End date] && dCalendar[Workday] = 1 ),
                    dCalendar[Date]
    Cherie
  • v-cherch-msft's avatar
    v-cherch-msft
    Hi palvarez83
    NextWkdyProd =
        FILTER (
            dCalendar,
            dCalendar[Date]
                = MINX (
                    dCalendar[Date]
    Cherie
    • JoeRobert06's avatar
      JoeRobert06
      Helper II
      I am having the same issue here, trying to make the filter context for a DAX table to be dynamce with either a slicer selection or a measure; see my below post as a reference. It looks like the method below is to wrap the argument with another filter() and then iterate across that table inside the original filter argument. I will try to see if solves my problem.
      palvarez83, did this solve your problem?
      Edit: I fogot to link my post, see below
      https://community.powerbi.com/t5/Desktop/Dynamic-filter-argument-within-table-expression/m-p/630026
      • palvarez83's avatar
        palvarez83
        Hi Joe,
        I did eventually solve a similar issue.  Apparently I was running into the "implied calculate" issue with my measure.  How I solved it was when the measure was defined, in the calculate with fillter, I enclosed the tabled name with ALL().  This thread show how I did something similar.
        https://community.powerbi.com/t5/Desktop/Lookup-DateKey-from-another-column-s-running-total/m-p/588868#M279273
