Help with dax filter function using measures as arguments.
- 7 years ago
Hi palvarez83
You may refer to below measure:
NextWkdyProd = CALCULATE ( SUM ( dCalendar[Productivity] ), FILTER ( dCalendar, dCalendar[Date] = MINX ( FILTER ( dCalendar, dCalendar[Date] > [End date] && dCalendar[Workday] = 1 ), dCalendar[Date] ) ) )Regards,
Cherie
Hi palvarez83
NextWkdyProd =
FILTER (
dCalendar,
dCalendar[Date]
= MINX (
dCalendar[Date]
)Regards,
Cherie
I am having the same issue here, trying to make the filter context for a DAX table to be dynamce with either a slicer selection or a measure; see my below post as a reference. It looks like the method below is to wrap the argument with another filter() and then iterate across that table inside the original filter argument. I will try to see if solves my problem.
palvarez83, did this solve your problem?
Edit: I fogot to link my post, see below
https://community.powerbi.com/t5/Desktop/Dynamic-filter-argument-within-table-expression/m-p/630026
- palvarez837 years agoHelper I
JoeRobert06 wrote:I am having the same issue here, trying to make the filter context for a DAX table to be dynamce with either a slicer selection or a measure; see my below post as a reference. It looks like the method below is to wrap the argument with another filter() and then iterate across that table inside the original filter argument. I will try to see if solves my problem.
Hi Joe,
I did eventually solve a similar issue. Apparently I was running into the "implied calculate" issue with my measure. How I solved it was when the measure was defined, in the calculate with fillter, I enclosed the tabled name with ALL(). This thread show how I did something similar.
