Hayden_RP's avatar
Hayden_RP
9 months ago
Difficulties connecting Oracle SQL Developer to Power BI
Hello, I'm trying to get a project for work running but am very new to Power BI. I receive an error that reads "Details: "Oracle: ORA-12154: TNS:could not resolve the connect identifier specified"
Oracle SQL is running fine and, I looked up some tutorials and I was reocmmended to download Oracle Client. I downloaded it but it doesn't seem to be doing much. Is there something I'm still not understanding?
  • d_m_LNK's avatar
    d_m_LNK
    9 months ago
    Hopefully your local admin can help you get things in the right spot.  For Power BI I believe it has to use the driver for the Microsoft products I specified before and the TSNames file needs to be in that directory as well.  Hopefull your admin can help you get things moved and installed correctly.
  • So Oracle SQL Developer connects to your Oracle Database. This is typically done using an ODBC connection. In PowerBI use the get data option and choose Other then try ODBC and choose the connection to your Oracle SQL server.
    If it's not that or the server isn't obvious have a chat to your DBA or IT team about it as they'll know the details of your setup
  • There is a TSNames.ora file in the oracle client install folder that needs to contain the connection information for your server.   Your system admin may have a copy of one to use.
    • Hayden_RP's avatar
      Hayden_RP
      What I'm finding is that I can't seem to find TSNames.ora anywhere even in client folder. I looked in Oracle SQL Developer and it appears as such:
      I think I'm confused in part because I don't know where to get that file in the first place and just need to figure out where to go from here.
  • v-karpurapud's avatar
    v-karpurapud
    Hi Hayden_RP
    Thank you for submitting your question to the Microsoft Fabric Community Forum, and thanks to d_m_LNK  and nrichards_au for offering helpful suggestions.
    Could you let us know if the suggested solution resolved your issue? If it's still pending, please let us know any further details so we can help.
    Best regards,
    Community Support Team
    v-karpurapud
    Hi Hayden_RP
    We have not received a response from you regarding the query and were following up to check if you had the opportunity to review the information provided. Please feel free to contact us if you have any further questions.
    Thank You.
