MichaelaMul's avatar
MichaelaMul
2 years ago
Difference between two different filter values in same column
I am trying to make a dax measure that finds the difference between a product and its overall category (group), filtering by entire category and specific product. Below, is sample data, with the yellow column showing what I would like. I have made the following measures but they are not working. Any suggestions are welcome!
Entire Category % Vol Sales =
CALCULATE(
	SUM('Table'[Volume Sales % Change vs YA]),
	ALL('Table'[Entire Category])
Brand % Vol Sales =
CALCULATE(
	ALL('Table'[Product])
Brand % Vol Sales minus Entire Category % Vol Sales =
[Brand % Vol Sales] - [Entire Category % Vol Sales]
Thanks!
Michaela
    2 years ago
    Hi MichaelaMul
    You can try thw following measure
    % Difference =
    VAR _volbyentirecate =
            SUM ( 'Table'[% Vol Sales Change] ),
            ALLSELECTED ( 'Table' ),
            'Table'[Entire Category] = MAX ( 'Table'[Category] ),
            'Table'[Manager] IN VALUES ( 'Table'[Manager] ),
            'Table'[Time] IN VALUES ( 'Table'[Time] )
    VAR _volbyproduct =
            'Table'[Category] <> BLANK (),
            'Table'[Product] IN VALUES ( 'Table'[Product] ),
        IF (
            MAX ( 'Table'[Category] ) <> BLANK (),
            _volbyproduct - _volbyentirecate,
            0
    Output
    Best Regards!
    Yolo Zhu
      • AUDISU's avatar
        AUDISU
        Icon for Resolver III rankResolver III
        HI MichaelaMul ,
        Create two new columns in power query.
        First column is Entire %
         If [Entire Category <> null then [%Vol Sales Change] else null
        Then fill down this new column.
        Second Column Difference Between Product Group
        If [Entire Category <> null then null else [Entire %] -  [%Vol Sales Change]
