MichaelaMul
Helper III
2 years agoDifference between two different filter values in same column
Hi, I am trying to make a dax measure that finds the difference between a product and its overall category (group), filtering by entire category and specific product. Below, is sample data, with the...
- Anonymous2 years ago
Hi MichaelaMul
You can try thw following measure
% Difference = VAR _volbyentirecate = CALCULATE ( SUM ( 'Table'[% Vol Sales Change] ), ALLSELECTED ( 'Table' ), 'Table'[Entire Category] = MAX ( 'Table'[Category] ), 'Table'[Manager] IN VALUES ( 'Table'[Manager] ), 'Table'[Time] IN VALUES ( 'Table'[Time] ) ) VAR _volbyproduct = CALCULATE ( SUM ( 'Table'[% Vol Sales Change] ), ALLSELECTED ( 'Table' ), 'Table'[Category] <> BLANK (), 'Table'[Product] IN VALUES ( 'Table'[Product] ), 'Table'[Manager] IN VALUES ( 'Table'[Manager] ), 'Table'[Time] IN VALUES ( 'Table'[Time] ) ) RETURN IF ( MAX ( 'Table'[Category] ) <> BLANK (), _volbyproduct - _volbyentirecate, 0 )Output
Best Regards!
Yolo Zhu
MichaelaMul
Helper III
2 years agohere's the sample data -
AUDISU
Resolver III
2 years agoHI MichaelaMul ,
Create two new columns in power query.
First column is Entire %
If [Entire Category <> null then [%Vol Sales Change] else null
Then fill down this new column.
Second Column Difference Between Product Group
If [Entire Category <> null then null else [Entire %] - [%Vol Sales Change]
