Anonymous's avatar
6 years ago
DAX Help - Define Variable Using Two Tables
Community,
I currently have three tables. I would like to use two of the tables to define a variable, then apply the variable along with values in the third table to calculate a value.
Below are the tables and what I would like to achieve, but getting the DAX correct has been a bit of a struggle, any help would be much appreciated. (Also in the example included, I would not have the option to merge any of the tables)
Create a Measure, CL_ATD1
  • Where CL_ATD1 = ((Slope[CL_x^2]*V)-(Slope[CL_x]*V))+(Slope[CL_icpt])
  • What is V?
    • V is the value where PassID[Pass ID] and ATD[Pass ID] match, then the column in PassID that has the value 100, retrieves the matching columns value from the ATD table where ATD[Attitude ID] = β€œ1”
    • In this example V = 1.5
  • In this example the measure CL_ATD1 =
    • ((0.00232795*1.5^2)-(0.000113306*1.5))+(-0.846558)
    • = -0.84149
  • Hi,
    Please unpivot table ATD and table PassID first:
    Table ATD:                                                         Table PassID:
    Then try this measure:
    Measure =
    var SameID = CALCULATE(MAX(ATD[Pass ID]),FILTER(ATD,ATD[Attitude ID]=ATD[Pass ID]))
    var Attribute = CALCULATE(MAX(PassID[Attribute]),FILTER(PassID,PassID[Pass ID]=SameID&&PassID[Value]=100))
    var variable = CALCULATE(MAX(ATD[Value]),FILTER(ATD,ATD[Attitude ID]=ATD[Pass ID]&&ATD[Attribute]=Attribute))
    return
    MAX(Slope[CL_x^2])*variable*variable-MAX(Slope[CL_x])*variable+MAX(Slope[CL_icpt])
    Choose a card visual, the result shows:
    Here is my test pbix file:
    pbix
    Hope this helps.
    Giotto Zhi
  • v-gizhi-msft's avatar
    v-gizhi-msft
    Measure =
    return
    pbix
    Hope this helps.
    Giotto Zhi
      v-gizhi-msft ,
      Thanks so much for the help!!
      Your DAX works perfect.
      v-gizhi-msft ,
      Do you have any thoughts on how to modify the DAX to solve for each of the different "Attitude ID"? The current DAX only solves for one of the "Attitude ID".
      I would like to end up with a table that looks something like this (CL_ATD1 is your measure in the original post), but with the correct calculated values. (In this example the variables need to muptiple with would be 1.5, 0, -1.5, -2.5, -3.5)
      I have tried introducing some HASONEVALUE in to the DAX but no luck in getting the correct values yet. Any help with this would be much appreciated. Also if you like I can make this a new post.
      Thanks!
