6 years agoNot applicable
DAX Help - Define Variable Using Two Tables
Community, I currently have three tables. I would like to use two of the tables to define a variable, then apply the variable along with values in the third table to calculate a value. Below are th...
- 6 years ago
Please unpivot table ATD and table PassID first:
Table ATD: Table PassID:
Then try this measure:
Measure = var SameID = CALCULATE(MAX(ATD[Pass ID]),FILTER(ATD,ATD[Attitude ID]=ATD[Pass ID])) var Attribute = CALCULATE(MAX(PassID[Attribute]),FILTER(PassID,PassID[Pass ID]=SameID&&PassID[Value]=100)) var variable = CALCULATE(MAX(ATD[Value]),FILTER(ATD,ATD[Attitude ID]=ATD[Pass ID]&&ATD[Attribute]=Attribute)) return MAX(Slope[CL_x^2])*variable*variable-MAX(Slope[CL_x])*variable+MAX(Slope[CL_icpt])Choose a card visual, the result shows:
Here is my test pbix file:
Hope this helps.
Giotto Zhi
