DAX - using variable in measure filter
Thanks speedramps for your reply.
The issue is ProductCategory being referred to by prodcat is a measure and not a column, your solution gives the below error:
A function 'PLACEHOLDER' has been used in a True/False expression that is used as a table filter expression. This is not allowed.
Hi SabineOussi
Sorry to hear that. I think perhaps you have not copied and pasted my measure.
It sound like you have created a prodcat measure and are trying to use that in the CALCULATE expression .... you cant' do that ... and will get a syntax error.
This measure however should be ok ... depending on your data model structure, which you didnt supply.
- SabineOussi4 years ago
Skilled Sharer
Thank you speedramps for your prompt response.
Here is a screenshot of the error with the provided measure LowSalesReasons_3
Actually, this is my initial posting with a link to an uploaded sample.
https://community.powerbi.com/t5/Desktop/Measure-Flagging-Performance/m-p/2129167
where I eventually replaced LowSalesReasons by the mentioned LowSalesReasons_1 or LowSalesReasons_2.
AggregateLowSalesReasons follows the same clauclation reasoning and will be replaced by the same solution provided here.Thank you,Sabine O.- v-easonf-msft4 years ago
Hi, SabineOussi
Has your problem been resolved? You can try to change the formula in your screenshot as follows.
owSalesReasons_3 = VAR target = [%_Target] VAR t2 = CALCULATE ( COUNTROWS ( ProductsDetails ), FILTER ( ProductsDetails, [ProductCategory] = "Tier 2" ) ) VAR t3 = CALCULATE ( COUNTROWS ( ProductsDetails ), FILTER ( ProductsDetails, [ProductCategory] = "Tier 3" ) ) VAR t4 = CALCULATE ( COUNTROWS ( ProductsDetails ), FILTER ( ProductsDetails, [ProductCategory] = "Tier 4" ) ) RETURN SWITCH ( TRUE (), target > 0.45, "Majority Sold", t2 > ( t3 + t4 ), "Low Sales Rates", t4 > ( t2 + t3 ), "High Inquiries", t3 > t2, "High Inquiries", "Low Sales Rates & High Inquiries" )Best Regards,
Community Support Team _ Eason- SabineOussi4 years ago
Skilled Sharer
Hello v-easonf-msft
Going back to this after a long vacation.
The solution provided returns correct results, however it is way slower than LowSalesReasons_1 (which was already slow and that was the main issue) and eventually prompts a not enough memory error even on PBI Service.
Error Message:
There's not enough memory to complete this operation. Please try again later when there may be more memory available.
Any idea?
Thanks.
Sabine O.
