DAX - using variable in measure filter
Hi SabineOussi
LowSalesReasons_2 is incorect because VAR prodcat only computes once and not for each row.
To improve speed try replace FILTER with CALCULATE and don't add the+ 0
Consider this solution and click the thumbs up button ....
- SabineOussi4 years ago
Skilled Sharer
Thanks speedramps for your reply.
The issue is ProductCategory being referred to by prodcat is a measure and not a column, your solution gives the below error:
A function 'PLACEHOLDER' has been used in a True/False expression that is used as a table filter expression. This is not allowed.- speedramps4 years ago
Hi SabineOussi
Sorry to hear that. I think perhaps you have not copied and pasted my measure.
It sound like you have created a prodcat measure and are trying to use that in the CALCULATE expression .... you cant' do that ... and will get a syntax error.
This measure however should be ok ... depending on your data model structure, which you didnt supply.
LowSalesReasons_3 =VAR target = [%_Target]VAR t2 =CALCULATE( COUNTROWS(ProductsDetails), ProductsDetails[ProductCategory] = "Tier 2")VAR t3 =CALCULATE( COUNTROWS(ProductsDetails), ProductsDetails[ProductCategory] = "Tier 3")VAR t4 =CALCULATE( COUNTROWS(ProductsDetails), ProductsDetails[ProductCategory] = "Tier 4")RETURNSWITCH(TRUE(),target > 0.45, "Majority Sold",t2 > (t3 + t4), "Low Sales Rates",t4 > (t2 + t3), "High Inquiries",t3 > t2, "High Inquiries","Low Sales Rates & High Inquiries")- SabineOussi4 years ago
Skilled Sharer
Thank you speedramps for your prompt response.
Here is a screenshot of the error with the provided measure LowSalesReasons_3
Actually, this is my initial posting with a link to an uploaded sample.
https://community.powerbi.com/t5/Desktop/Measure-Flagging-Performance/m-p/2129167
where I eventually replaced LowSalesReasons by the mentioned LowSalesReasons_1 or LowSalesReasons_2.
AggregateLowSalesReasons follows the same clauclation reasoning and will be replaced by the same solution provided here.Thank you,Sabine O.
