6 years agoNot applicable
Create a calculated column based on duplicated values in another column (Using Dax only)
Greeting all , i have this table in power BI (this is just a small example so i can use it later on the project ) : i want to create a calculated column named "duplicate" where it hav...
v-diye-msft
6 years agoHi Anonymous
Not quite understand your logic, would you like to get below results?
Measure = var a = CALCULATE(MIN('Table'[Number of aplies]),ALLEXCEPT('Table','Table'[Title]))
Return
IF(MAX('Table'[Number of aplies])=a,1,0)
Or this one:
Column = var a = [Title]
var b = RANKX(FILTER('Table',[Title]=a),[Number of aplies],,ASC)
return IF(b=1,1,0)
Pbix attached.
Thanks for your reply , but your solution works only if i dont have the same number of applies for every title
what im trying to acheive here is to create a column where i can use it later to filter my table without showing duplicated values of my title !
the object here that im trying to dislay a table in my report where i show the list of the titles (i need to remove the duplicate values here just for the visual )
