mh2587's avatar
mh2587
4 years ago
Calculate difference between two values in same column without time intelligence
I have single integer column , trying to calculate difference without any date or year or month column
E.g
     Column X                            Expected Diff
           14                                           0
             9                                     14-9= 6
             3                                      9-3=6
Thank you
  • Hi mh2587 ,
    Create an index column and try the following formula:
    Column 2 =
    VAR cur_index = 'Table'[Index]
        IF (
            cur_index - 1 < 0,
            0,
                MAX ( 'Table'[Column] ),
                ALL ( 'Table' ),
                'Table'[Index] = cur_index - 1
            ) - 'Table'[Column]
    If the problem is still not resolved, please provide detailed error information and let me know immediately. Looking forward to your reply.
    Henry
  • mh2587 ,
    You need add an index column in power query the
    a new column =
    [Columnx] - Maxx(filter(Table, [Index] = earlier([Index]) -1 ),[ColumnX])
    • mh2587's avatar
      mh2587
      Thanks for the response i will try that way
  • v-henryk-mstf's avatar
    v-henryk-mstf
    Hi mh2587 ,
    Column 2 =
        IF (
            cur_index - 1 < 0,
            0,
                ALL ( 'Table' ),
            ) - 'Table'[Column]
    Henry
