udian's avatar
udian
10 years ago
All Function Ignored When Using Power BI in Direct Query Mode
Hi All,
I am using Power BI in direct query mode to query a tabular cube (the cube was created manually).
One of the measures in the cube contains ALL() function in order to ignore user filtering on time dimension.
When i query the cube using Power BI in direct query mode the measure doesn't ignore the user filtering and the measure is filtered on a single month, but when i connect to the tabular cube with excel and preform the same query (same measure and filters) i get the correct result and i can see the measure value for the diferrent months.
below you can see the query output from sql profiler for both query methods:
Power BI:
EVALUATE
TOPN(
501,
CALCULATETABLE(
ADDCOLUMNS(
KEEPFILTERS(
FILTER(
KEEPFILTERS(VALUES('Dim_Transaction_TimeTable'[MonthDate])),
NOT(ISBLANK('Fact_Volume'[First_Loaders_Last_In_6_Months3]))
"First_Loaders_Last_In_6_Months3", 'Fact_Volume'[First_Loaders_Last_In_6_Months3]
KEEPFILTERS(
FILTER(
KEEPFILTERS(VALUES('Dim_Last_6_Months'[MonthDate])),
'Dim_Last_6_Months'[MonthDate] = DATE(2016, 8, 1)
'Dim_Transaction_TimeTable'[MonthDate],
1
ORDER BY
Excel:
SELECT NON EMPTY Hierarchize({DrilldownLevel({[Dim_Transaction_TimeTable].[MonthDate].[All]},,,INCLUDE_CALC_MEMBERS)}) DIMENSION PROPERTIES PARENT_UNIQUE_NAME,HIERARCHY_UNIQUE_NAME ON COLUMNS FROM [Model] WHERE ([Dim_Last_6_Months].[MonthDate].&[2016-08-01T00:00:00],[Measures].[First_Loaders_Last_In_6_Months3]) CELL PROPERTIES VALUE, FORMAT_STRING, LANGUAGE, BACK_COLOR, FORE_COLOR, FONT_FLAGS
Does anyone know the reason for this strange behaviour or how to solve this?
Udi
  • udian
    I don’t think this is possible in Direct Query Mode. When you select a leading month, the table will always be filtered based on your selection in the slicer, unless you edit interactions to none. But in that case, the table visual will never be filtered. As I said before, the ALL function will ignore the filter from the slicer in the measure calculation, but will not impact the table visual display.
    I suggest you use one more slicer like Timeline to select the last 12 months and control the rows shown in the table chart.
    Herbert
  • Greg_Deckler's avatar
    Greg_Deckler
    Try File | Options and settings | Options | DirectQuery -> Allow unresticted measures.
    • udian's avatar
      udian
      Thanks for the quick reply.
      Already tried that before posting...doesn't solve the problem.
      • v-haibl-msft's avatar
        v-haibl-msft
        udian
        I just created a simple measure which using ALL() function in Direct Query Mode, it worked well as below.
        Herbert
