All Function Ignored When Using Power BI in Direct Query Mode
- 10 years ago
I don’t think this is possible in Direct Query Mode. When you select a leading month, the table will always be filtered based on your selection in the slicer, unless you edit interactions to none. But in that case, the table visual will never be filtered. As I said before, the ALL function will ignore the filter from the slicer in the measure calculation, but will not impact the table visual display.
I suggest you use one more slicer like Timeline to select the last 12 months and control the rows shown in the table chart.
Herbert
Try File | Options and settings | Options | DirectQuery -> Allow unresticted measures.
- udian10 years ago
Helper III
Thanks for the quick reply.
Already tried that before posting...doesn't solve the problem.
- v-haibl-msft10 years ago
I just created a simple measure which using ALL() function in Direct Query Mode, it worked well as below.
Herbert
- udian10 years ago
Helper III
Hi Herbert,
Appreciate you testing the scenario on your side!
I simplified my measure for simpler testing and it still doesn't work.
This is my test measure:
First_Loaders :=CALCULATE(1000,all(Dim_Last_6_Months))
and this is the result:
As you can see, instead of getting one row for each month with the value 1000 i get only one row for July meaning that the measure ignores the all function.
The month slicer in the image is based on a table containing only 6 records for the last 6 months. The "Last 6 Months" dimesion is connected to the full time dimesion with the MonthDate column (MonthDate = the date of the fisrt day of the month).
Any ideas why it is not working for my measure?
Thanks!
