I have a Power Automate flow, which uses a premium connector (HTTP, enhanced refresh in Power BI API) and is triggered from a button within a Power BI report.
My user has a Power BI Premium-per-User license and Flow Free license, in addition to "Plan 1" for O365.
When I click the button, everything works fine.
When one of the "run only" users clicks the button - the flow is not triggered.
The "run only" users have Power BI Premium-per-User license, but no basic O365 (they use Google services) or Power Automate license.
What do I need to do in order to make this button work for all the "run only" users?
Thanks.
Hi @EffratK ,
Your end-users need a license and is the root cause. Please see the most recent licensing guide here: https://go.microsoft.com/fwlink/?linkid=2085130 .
My recommendation is to consider the least expensive option for this subset of users that may need to use this button in Power BI.
I think the "run only user" runs the flow as the user, meaning they would need a license. In most other cases, it runs the flow under the single connection that the flow was configured to use, so you'd be fine, I think it's the run-only user thing that's causing the issue here.
