Join us at FabCon Vienna from September 15-18, 2025, for the ultimate Fabric, Power BI, SQL, and AI community-led learning event. Save €200 with code FABCOMM. Get registered
TedPattison
Building Multi-language Reports for Power BI in 2023
We're excited about the January session of Power BI Dev Camp because we want to tell you about several new enhancements to Power BI which make it much easier to build multi-language reports. The USERCULTURE function is now fully supported and this essential DAX function provides the ability to write measures which implement report label translations dynamically. There are also several new properties for report visuals and shapes that can be configured to use these measure with dynamic translations. Finally, Power BI released a powerful, new feature named Field Parameters which offer a much better approach to implement data translations.
The Power BI Dev Camp session for January 2023 has been created to provide guidance and to teach campers the skills required to build Power BI reports that support multiple languages. You need to learn a few key concepts about how Power BI translations work and you also need to learn how to automate repetitive tasks that would take forever to complete manually. Once you understand how all the pieces fit together, you’ll be able to build multi-language reports for Power BI using a strategy that is reliable, predictable and scalable.
Prerequisites: Campers must have experience building queries, datasets and reports with Power BI Desktop.
Date and Time: Thursday January 26th at 2:00 PM EST | 11:00 AM PST
Attendee Linkhttps://aka.ms/DevCampLive
Additonal Learning Resources:
Comments
