- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Report Inappropriate Content
Issues with Power bi and Power BI 64
I'm getting this errors when starting Power BI and Power BI 64 so, it is not a ·" bit operating system problem: I'm running
Widows 7 Service Pack 1 64bit operating system
on a HP 250 G4 notebook PC
with intel i3 5005U CPU 2.00 GHz
8 GB ram
Feedback Type:
Frown (Error)
Error Message:
Resolution of the dependency failed, type = "Microsoft.PowerBI.Client.Windows.MainForm", name = "(none)".
Exception occurred while: Calling constructor Microsoft.PowerBI.Client.Windows.MainForm(Microsoft.Mashup.Client.UI.Shared.ILegacyUIHost uiHost, Microsoft.PowerBI.Client.Shared.IPowerBISettings powerBISettings, Microsoft.PowerBI.Client.Windows.IBrowserFactory browserFactory, Microsoft.PowerBI.Client.Windows.Services.IPowerBITelemetryService telemetryService, Microsoft.PowerBI.Client.Windows.Services.IPowerBIWindowServiceFactory windowServiceFactory, Microsoft.PowerBI.Client.Windows.Services.IUIBlockingService uiBlockingService, Microsoft.PowerBI.Client.Windows.Diagnostics.IDiagnosticInformationService diagnosticsInfoService, Microsoft.PowerBI.Client.Shared.ISystemEnvironment systemEnvironment, Microsoft.PowerBI.Client.Windows.Services.IEventAggregationService eventAggregationService).
Exception is: ResolutionFailedException - Resolution of the dependency failed, type = "Microsoft.PowerBI.Client.Windows.Services.IStoragePropertiesProvider", name = "(none)".
Exception occurred while: Calling constructor Microsoft.PowerBI.Client.Windows.Services.StoragePropertiesProvider().
Exception is: TypeInitializationException - Se produjo una excepción en el inicializador de tipo de 'Microsoft.PowerBI.Client.Windows.Services.StoragePropertiesProvider'.
<HandleExceptionsWithNestedTasks>b__0()
en Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
Stack Trace Message:
PowerBIUserFeedbackServices_IsReported:
True
allyklee
on: Remove / Copy Visual issue - July 2025 Desktop Iss...
- stipa on: Error "[403.12–403.30] The name 'Lakehouse.Content...
klinejordan
on: URL is not filtering on field parameter
- MaAl on: "The import PowerPlatform.Dataflows matches no exp...
NikNithiy
on: URGENT!! Paginated Report not loading on Mozilla F...
- duarte on: Unable to sort months in PowerBI
- zsombor on: Matrix Visual doesn't work with Field Parameters ...
mattlee on: “Add Value” in Textbox Not Visible in Dark Theme
- mattin on: Report Server Permissions Jan/May 2025
bhalicki
on: Bi Crashes on launch with (AS Process PID=XXXXXX H...
- New 8,049
- Needs Info 3,502
- Investigating 3,602
- Accepted 2,088
- Declined 38
- Delivered 3,970
Reports
10,247 -
Data Modeling
4,135 -
Dashboards
4,116 -
Report Server
2,116 -
Gateways
2,116 -
APIS and Embedding
1,966 -
Custom Visuals
1,790 -
Content Packs
525 -
Mobile
354 -
Need Help
11 -
Show and Tell
3 -
General Comment
2 -
Tips and Tricks
1 -
Power BI Desktop
1
