- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Report Inappropriate Content
Bug - Power BI Dataflow with connection to other Power BI data flow fails in refreshing
Created a Power BI Dataflow with the connection to other existing Power BI data flow using "Dataflow" connector, worked in the editing, but failed in refreshing once saved it.
Switched the connector from "Dataflow" to "Power BI Dataflow (Legacy)" and worked.
Dataflow connector has the issue with connecting to other Power BI dataflow when refreshing data. The refresh error message was
"Error: Data Source Error : DataSource.Error: Microsoft SQL: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider error: 40 - Could not open a connection to SQL Server) DataSourceKind = <ccon>PowerPlatformDataflows</ccon> DataSourcePath = <ccon>PowerPlatformDataflows</ccon> Message = <ccon>A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections".
- joakims on: "The import PowerPlatform.Dataflows matches no exp...
NikNithiy
on: URGENT!! Paginated Report not loading on Mozilla F...
- duarte on: Unable to sort months in PowerBI
mattlee on: “Add Value” in Textbox Not Visible in Dark Theme
- mattin on: Report Server Permissions Jan/May 2025
bhalicki
on: Bi Crashes on launch with (AS Process PID=XXXXXX H...
- stanteitelbaum on: authenticator wont trigger after purchase of new p...
Stinkys
on: Fix the Date function in DAX
Stinkys
on: Cannot login to community site
reubwork
on: May 25 update for Snowflake Connector v2 has broke...
- New 8,025
- Needs Info 3,502
- Investigating 3,602
- Accepted 2,088
- Declined 38
- Delivered 3,970
Reports
10,232 -
Data Modeling
4,130 -
Dashboards
4,114 -
Report Server
2,114 -
Gateways
2,112 -
APIS and Embedding
1,965 -
Custom Visuals
1,789 -
Content Packs
523 -
Mobile
354 -
Need Help
11 -
Show and Tell
3 -
General Comment
2 -
Tips and Tricks
1 -
Power BI Desktop
1
