Refresh Power BI Dataset using Power Automate (flow) with Viewer permissions in app workspace
Hi all,
Hope you are doing good!
I have a scenario which is a head scratcher for me. need your inputs 🙂
I am refreshing a Power BI dataset via a flow. UI is Power Apps platform which takes dates as an inputs and through flow it refreshes the Power BI dataset.
I am managing access to power bi app workspace via Security groups.
Now, If I am user in a particualr Security Group and that SG has 'Viewer' access to my app workspace, flow fails saying user doesn't have sufficient permissions (since it is not able to find dataset).
If I change the access level to one higher i.e. 'Contributor' access to that Security group then the cons is - I am providing users of that SG powers to delete content and acces more information than needed because they should only have read access.
What should be the ideal implementation scenrio for me ?
This is the dilemma! would love your inputs.  Hope I made it clear to understand, if not just throw your doubts please.
Thanks in advance!
3 ACCEPTED SOLUTIONS
otravers
You should be able to solve this conundrum by using a service principal:
https://benediktbergmann.eu/2022/01/04/setup-a-service-principal-in-power-automate/
1. How to get your question answered quickly - good questions get good answers!
2. Learning how to fish > being spoon-fed without active thinking.
3. Please accept as a solution posts that resolve your questions.
BI Blog: Datamarts | RLS/OLS | Dev Tools | Languages | Aggregations | XMLA/APIs | Field Parameters | Custom Visuals
ibarrau
Hi. Like otravers says you might want to use a service account (like service pricipal). The main thing here is that the user or account used to refresh needs more permissions, so it can't be inside of a security group that can only "View" inside the workspace. The service principal is usually the best option because it doesn't depends on a user, it's an app registered for the organization.
I hope that make sense
Happy to help!
LaDataWeb Blog
Thanks for your relpies @otravers  @ibarrau
Well this is the ideal solution which should be implemented from the start. Thanks for letting me know.
Also, the other solution which worked in my specific case is just run the flow with the account which has higher level of permissions (like @ibarrau mentioned in his answer). The new task (PowerApps V2) inside flow allows to do this.
This way we can restrict user from Power BI workspace perspective but at the same time can allow them to just refresh the dataset.
Thanks for your help guys!!
How can you use PowerApps V2 trigger to run the flow with a different account?
ibarrau
Happy to help!
LaDataWeb Blog
otravers
