ahmadov_10's avatar
ahmadov_10
Helper II
5 years ago
using a current value for a column from Previous STEP - Power Query
Hello Experts,
My business need with Power Query :
I'm tried to save the same values in the columns (id_bu_rh) and (id_bu_ctr) ( a completed list of id) : for these reason i created the step Duplicated Column .
after i have a modification step called #"distinct annee, mois" : this is essential for work (but this step affects (id_bu_rh) , (id_bu_ctr) which become only with values : (0,1))
So I want to make a step that combine the columns
of #"distinct annee, mois" with the columns (id_bu_rh) , (id_bu_ctr) in the previous step Duplicated Column (or navigation)
this is my code this my power Query code and i think I am close to the result : just to fix how to call an element value (column) from a previous step :
Source = PostgreSQL.Database("localhost", "datamart"),
polaris_datamart_fait_ca = Source{[Schema="polaris_datamart",Item="all_combinationations_v"]}[Data],
#"Duplicated Column" = Table.DuplicateColumn(polaris_datamart_fait_ca, "id_bu_rh", "id_bu_rh - Copy"),
#"distinct annee, mois" = Table.Distinct(#"Duplicated Column", {"annee", "mois"}),
#"step_final" = Table.AddColumn(#"distinct annee, mois","col_bu_RH", each (#"Duplicated Column"[id_bu_rh]))
#"step_final"
( amitchandak   , selimovd   parry2k  , Greg_Deckler  Pragati11  MarcelBeug v-qiuyu-msft
 and all community of super stars , i need your helps ). BEST REGARDS
This is my screenshots below
  • ahmadov_10 not sure I followed this step, you are creating a list with two values "anee and mois"
    what you are trying to achieve here, I'm not fully sure from your post.
    • ahmadov_10's avatar
      ahmadov_10
      Helper II
      Hi parry2k ,
      your remark is very relevant : the step distinct (annee,month) is created with an old version in the project and i tried to understand it : i find in database editor with SQL query , that this is step is similar to over partition to save one row only for each (year , month) and the first row was always with id =0 or 1. so when we call the previous step that contains all the id to make an append operation (pervious id) to the actual step (actual id) ---> it will be the same , no changes (0,1) , and no errors.
      because  : previous step : the completed table = 5000 rows
      actual step (distinct (annee,mois) = 49 rows
      Many thanks for you and Pragati11  : I accept your answer as solution
  • Hi ahmadov_10 ,
    I am not very much clear on the requirement. Can you add more details please?
    Pragati
