Vetri_BI
perform a simple matrix addition between two tables using power query
for my business requirement  i need to add two matrix. and get a resultant matrix. i know how to do it if the the number of column is small and manually entering the columns. but for my case the number of columns is high. so i need to dynamically iterate across columns.
(Table 1)Matrix A:
12
34
(Table 2)Matrix B:
56
78
I need the following result
Result table:
68
1012
i need to achieve this result without manually using the column names.
If anyone could find the solution , it would be really helpful. Thanks.
Some notes.
after spending hours on google i was able to find a blog(https://querypower.com/2017/02/24/powerquery-matrix-multiplication/) for performing matrix multiplication. which is not what i want but is slightly relevant to this question
slorin
Hi
= Table.FromColumns(
List.Transform(
List.Zip(
{Table.ToColumns(MatrixA),
Table.ToColumns(MatrixB)}),
each List.Transform(
List.Zip({_{0},_{1}}),
List.Sum)
Stéphane
slorin
Hi
List.Transform(
List.Zip(
List.Sum)
Stéphane
@slorin Thanks a lot for your reply , the solution worked like magic(My brain cannot comprehend how loop/iteration works in Power query).
for people who want to use this matrix addition query here is the complete power query. that i copied from @slorin 's solution.
A = Table.FromRows(
{1, 2},
{3, 4}
B = Table.FromRows(
{5, 6},
{7, 8}
Addition = (MatrixA , MatrixB) => {
Table.FromColumns(
List.Transform(
List.Zip(
List.Sum)
resultMatrix = Addition(A,B){0}
resultMatrix
Vetri_BI
Here's some power query for the two tables. that will save some time,
A = Table.FromRows(
{1, 2}
{3, 4}
B = Table.FromRows(
{5, 6},
{7, 8}
Addition = (table1 , table2) => ....Need Help here....
The below is the expected result.
resultMatrix = Table.FromRows(
{6, 8},
{10, 12}
