Hi everyone,
I am having some issues with doing this as underneath:
I would like to groupBY RemoteID_shaped column and keep only rows =6 in MediaType column while substracting for each RemoteID_shaped number row in column TerminatedDateTimeUTC that has column MediaType =6 from MAX(TerminatedDateTimeUTC ) rows that has column MediaType =0.
any help will be much appreciated.
Thank you in advance.
Gmooh.
Hi @Anonymous
please paste this code into the advanced editor and follow the steps:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZU5bsMwEEWvEqg2YM7GrXQOkAMYLpyki5E08f1DUXDD4QjjdMKHnt6I+CTP5wUDF2EBSstheb3ebqfrx1d7BDoGPGLA8AJSuQxRrCLL5TDwb/ff95/796fiBWaRl+8yyy8hh9I+IPb8qcLIp4qkecPv5g1/rhRUxOz2Nx4tngOlDAWY9vyo/USaN/2o/e2XnH4MNUQVUfb6/bzpZ1GRTOY3/RO+bYnOQ6QgGQvb6x8rRdUfjpo3+9+nU5GXT2r9tsg7fyu77j9N/t/0o/Y/+uPj0yza+CwJAkXY7X8eolJhwpv9F55FXr7LPH6zv8A6Eq9/e9ngBbhkwshxr7849q8diaR5s784rl+P/P5x/61ResI/4SU/w4/9jY/92/kEEfbXb7w/03okKP4f95/Hn6bnT3DzRfVvjfzz95c9vH1/oIpgMr99f2i+RZfLHw==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [RemoteID = _t, MediaType_name = _t, ConnectedDate = _t, TerminatedDate = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"RemoteID", Int64.Type}, {"MediaType_name", type text}, {"ConnectedDate", type datetime}, {"TerminatedDate", type datetime}}),
#"Grouped Rows" = Table.Group(#"Changed Type", {"RemoteID"}, {{"CallBacks", each Table.SelectRows(_, each [MediaType_name] = "CallBack")}, {"Outbounds", each Table.SelectRows(_, each [MediaType_name] = "Outbound")}}),
#"Expanded CallBacks" = Table.ExpandTableColumn(#"Grouped Rows", "CallBacks", {"MediaType_name", "ConnectedDate", "TerminatedDate"}, {"MediaType_name", "ConnectedDate", "TerminatedDate"}),
DiffTerminatedDate = Table.AddColumn(#"Expanded CallBacks", "Diff-TerminatedDate", each [TerminatedDate] - List.Max([Outbounds][TerminatedDate])),
#"Added Custom" = Table.AddColumn(DiffTerminatedDate, "Diff-ConnectedDate", each [ConnectedDate] - List.Min([Outbounds][ConnectedDate]))
#"Added Custom"
The reason for asking for sample data is that seeing the desired result helps understanding the explanations for the problem/requirements. And prevents silly code, as one can detect small errors or typos in the description.
This was missing from what you've sent so I have not been able to check if the negative amounts are really correct here.
Hi @Anonymous
that's possible, for sure. Please provide link to some sample data that provides the original data and the desired output.
Hi @ImkeF ,
I would like to GROUPBY RemoteID Column as well as add to columns:
Diff-TerminatedDate = TerminatedDate(for each row: CallBack)-MAX(TerminatedDate(of all Outbound rows for the same RemoteID)
Diff-ConnectedDate = ConnectedDate(for each row: CallBack)-Min(ConnectedDate( of all Outbound rows for the same RemoteID))
Here is my table Data sample synthesized with 2 added Columns:
| RemoteID | MediaType_name | ConnectedDate | TerminatedDate | Diff-Terminated |
| 2046125564 | CallBack | 2020-02-13 12:23:01 | 2020-02-13 12:34:36 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 2046125564 | Outbound | 2020-02-13 12:26:09 | 2020-02-13 12:32:36 | - |
| 2049545137 | CallBack | 2020-02-13 15:49:11 | 2020-02-13 16:55:25 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 2049545137 | Outbound | 2020-02-13 15:51:34 | 2020-02-13 15:51:37 | - |
| 2049545137 | Outbound | 2020-02-13 16:55:13 | 2020-02-13 16:55:15 | - |
| 2508094515 | CallBack | 2020-02-13 17:15:09 | 2020-02-13 17:23:44 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 2508094515 | Outbound | 2020-02-13 17:15:31 | 2020-02-13 17:23:26 | - |
| 2508094515 | CallBack | 2020-02-13 18:30:08 | 2020-02-13 18:44:36 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 2508094515 | Outbound | 2020-02-13 18:32:25 | 2020-02-13 18:44:09 | - |
| 4037819143 | CallBack | 2020-02-13 18:20:51 | 2020-02-13 18:33:21 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4037819143 | Outbound | 2020-02-13 18:22:17 | 2020-02-13 18:30:01 | - |
| 4037819143 | CallBack | 2020-02-13 20:06:07 | 2020-02-13 20:38:01 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4037819143 | Outbound | 2020-02-13 20:06:19 | 2020-02-13 20:38:30 | - |
| 4037819143 | CallBack | 2020-02-13 20:45:12 | 2020-02-13 20:50:58 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4037819143 | Outbound | 2020-02-13 20:45:21 | 2020-02-13 20:49:49 | - |
| 4163058294 | CallBack | 2020-02-13 16:36:59 | 2020-02-13 17:46:31 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4163058294 | Outbound | 2020-02-13 16:43:00 | 2020-02-13 16:43:07 | - |
| 4163058294 | Outbound | 2020-02-13 17:06:36 | 2020-02-13 17:06:42 | - |
| 4163058294 | CallBack | 2020-02-13 17:25:49 | 2020-02-13 17:39:23 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4163058294 | Outbound | 2020-02-13 17:26:12 | 2020-02-13 17:30:21 | - |
| 4163058294 | Outbound | 2020-02-13 17:27:15 | 2020-02-13 17:27:22 | - |
| 4185710361 | CallBack | 2020-02-13 18:28:51 | 2020-02-13 19:17:59 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4185710361 | Outbound | 2020-02-13 18:54:52 | 2020-02-13 18:54:55 | - |
| 4185710361 | Outbound | 2020-02-13 19:17:37 | 2020-02-13 19:17:52 | - |
| 4185710361 | CallBack | 2020-02-13 20:14:57 | 2020-02-13 20:15:48 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 4185710361 | Outbound | 2020-02-13 20:15:42 | 2020-02-13 20:15:53 | - |
| 5149832646 | CallBack | 2020-02-13 16:23:34 | 2020-02-13 17:13:09 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 5149832646 | Outbound | 2020-02-13 16:24:16 | 2020-02-13 16:24:43 | - |
| 5149832646 | CallBack | 2020-02-13 16:45:31 | 2020-02-13 16:47:50 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 5149832646 | Outbound | 2020-02-13 16:45:57 | 2020-02-13 16:58:45 | - |
| 5149832646 | Outbound | 2020-02-13 16:46:54 | 2020-02-13 16:46:59 | - |
| 5149871616 | CallBack | 2020-02-13 16:29:57 | 2020-02-13 17:36:47 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 5149871616 | Outbound | 2020-02-13 16:55:03 | 2020-02-13 16:55:10 | - |
| 5149871616 | CallBack | 2020-02-13 17:36:00 | 2020-02-13 17:40:44 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 5149871616 | CallBack | 2020-02-13 19:14:54 | 2020-02-13 19:16:58 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 5149871616 | Outbound | 2020-02-13 19:16:19 | 2020-02-13 19:16:48 | - |
| 5149871616 | CallBack | 2020-02-13 20:02:13 | 2020-02-13 20:10:39 | TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound) |
| 5149871616 | Outbound | 2020-02-13 20:02:16 | 2020-02-13 20:02:35 | - |
Here is the Output that I would like to have:
Hi @ImkeF ,
I would like to do a GROUP BY RemoteID Column and then add 2 new columns Diff-TerminatedDate and Diff-ConnectedDate as below:
Here is my table Data sample synthesized:
The output will be as below:
| RemoteID | MediaType_name | ConnectedDate | TerminatedDate | Diff-TerminatedDate | Diff-ConnectedDate |
| 2049545137 | CallBack | 2020-02-13 15:49:11 | 2020-02-13 16:55:25 | ||
| 2508094515 | CallBack | 2020-02-13 17:15:09 | 2020-02-13 17:23:44 | ||
| 2508094515 | CallBack | 2020-02-13 18:30:08 | 2020-02-13 18:44:36 | ||
| 4037819143 | CallBack | 2020-02-13 18:20:51 | 2020-02-13 18:33:21 | ||
| 4037819143 | CallBack | 2020-02-13 20:06:07 | 2020-02-13 20:38:01 | ||
| 4037819143 | CallBack | 2020-02-13 20:45:12 | 2020-02-13 20:50:58 | ||
| 4163058294 | CallBack | 2020-02-13 16:36:59 | 2020-02-13 17:46:31 | ||
| 4163058294 | CallBack | 2020-02-13 17:25:49 | 2020-02-13 17:39:23 | ||
| 4185710361 | CallBack | 2020-02-13 18:28:51 | 2020-02-13 19:17:59 | ||
| 4185710361 | CallBack | 2020-02-13 20:14:57 | 2020-02-13 20:15:48 | ||
| 5149832646 | CallBack | 2020-02-13 16:23:34 | 2020-02-13 17:13:09 | ||
| 5149832646 | CallBack | 2020-02-13 16:45:31 | 2020-02-13 16:47:50 | ||
| 5149871616 | CallBack | 2020-02-13 16:29:57 | 2020-02-13 17:36:47 | ||
| 5149871616 | CallBack | 2020-02-13 17:36:00 | 2020-02-13 17:40:44 | ||
| 5149871616 | CallBack | 2020-02-13 19:14:54 | 2020-02-13 19:16:58 | ||
Hi @Anonymous
#"Added Custom"
Hi @ImkeF ,
Thank you for your reply, please forgive my bad explanantion :).
I will check that and try to implement it to my code.I will let you know ASAP.
Thanks.
Hi everyone,
Could anyone help on this please ?
Much appreciated.
Thanks.
Hi @Anonymous
Sorry, misses your answer.
Will check it out in a sec.
Hi @Anonymous
could you please check the data for the desired output?
I cannot see any calculation there. So its just a selection of the first 4 items with "MediaType" = "CallBack"
Please make sure that the desired input and output match each other completely.
Thanks ImkeF, much appreciated.
| 9 | |
| 7 | |
| 7 | |
| 3 | |
| 3 |
| 22 | |
| 14 | |
| 11 | |
| 10 | |
| 9 |
