Get Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
need help on how to substract rows max - min in column TerminatedDate that fullfill some criteria.
Hi everyone,
I am having some issues with doing this as underneath:
I would like to groupBY RemoteID_shaped column and keep only rows =6 in MediaType column while substracting for each RemoteID_shaped number row in column TerminatedDateTimeUTC that has column MediaType =6 from MAX(TerminatedDateTimeUTC ) rows that has column MediaType =0.
any help will be much appreciated.
Thank you in advance.
Gmooh.
ImkeF
Hi @Anonymous
please paste this code into the advanced editor and follow the steps:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZU5bsMwEEWvEqg2YM7GrXQOkAMYLpyki5E08f1DUXDD4QjjdMKHnt6I+CTP5wUDF2EBSstheb3ebqfrx1d7BDoGPGLA8AJSuQxRrCLL5TDwb/ff95/796fiBWaRl+8yyy8hh9I+IPb8qcLIp4qkecPv5g1/rhRUxOz2Nx4tngOlDAWY9vyo/USaN/2o/e2XnH4MNUQVUfb6/bzpZ1GRTOY3/RO+bYnOQ6QgGQvb6x8rRdUfjpo3+9+nU5GXT2r9tsg7fyu77j9N/t/0o/Y/+uPj0yza+CwJAkXY7X8eolJhwpv9F55FXr7LPH6zv8A6Eq9/e9ngBbhkwshxr7849q8diaR5s784rl+P/P5x/61ResI/4SU/w4/9jY/92/kEEfbXb7w/03okKP4f95/Hn6bnT3DzRfVvjfzz95c9vH1/oIpgMr99f2i+RZfLHw==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [RemoteID = _t, MediaType_name = _t, ConnectedDate = _t, TerminatedDate = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"RemoteID", Int64.Type}, {"MediaType_name", type text}, {"ConnectedDate", type datetime}, {"TerminatedDate", type datetime}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"RemoteID"}, {{"CallBacks", each Table.SelectRows(_, each [MediaType_name] = "CallBack")}, {"Outbounds", each Table.SelectRows(_, each [MediaType_name] = "Outbound")}}),
    #"Expanded CallBacks" = Table.ExpandTableColumn(#"Grouped Rows", "CallBacks", {"MediaType_name", "ConnectedDate", "TerminatedDate"}, {"MediaType_name", "ConnectedDate", "TerminatedDate"}),
    DiffTerminatedDate = Table.AddColumn(#"Expanded CallBacks", "Diff-TerminatedDate", each [TerminatedDate] - List.Max([Outbounds][TerminatedDate])),
    #"Added Custom" = Table.AddColumn(DiffTerminatedDate, "Diff-ConnectedDate", each [ConnectedDate] - List.Min([Outbounds][ConnectedDate]))
    #"Added Custom"
The reason for asking for sample data is that seeing the desired result helps understanding the explanations for the problem/requirements. And prevents silly code, as one can detect small errors or typos in the description.
This was missing from what you've sent so I have not been able to check if the negative amounts are really correct here.
10 REPLIES 10
ImkeF
Hi @Anonymous
that's possible, for sure. Please provide link to some sample data that provides the original data and the desired output.
Hi @ ,
I would like to GROUPBY RemoteID Column as well as add to columns:
Diff-TerminatedDate = TerminatedDate(for each row: CallBack)-MAX(TerminatedDate(of all Outbound rows for the same RemoteID)
Diff-ConnectedDate = ConnectedDate(for each row: CallBack)-Min(ConnectedDate( of all Outbound rows for the same RemoteID))
Here is my table Data sample synthesized with 2 added Columns:
RemoteIDMediaType_nameConnectedDateTerminatedDateDiff-Terminated
2046125564CallBack2020-02-13 12:23:012020-02-13 12:34:36TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
2046125564Outbound2020-02-13 12:26:092020-02-13 12:32:36-
2049545137CallBack2020-02-13 15:49:112020-02-13 16:55:25TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
2049545137Outbound2020-02-13 15:51:342020-02-13 15:51:37-
2049545137Outbound2020-02-13 16:55:132020-02-13 16:55:15-
2508094515CallBack2020-02-13 17:15:092020-02-13 17:23:44TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
2508094515Outbound2020-02-13 17:15:312020-02-13 17:23:26-
2508094515CallBack2020-02-13 18:30:082020-02-13 18:44:36TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
2508094515Outbound2020-02-13 18:32:252020-02-13 18:44:09-
4037819143CallBack2020-02-13 18:20:512020-02-13 18:33:21TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4037819143Outbound2020-02-13 18:22:172020-02-13 18:30:01-
4037819143CallBack2020-02-13 20:06:072020-02-13 20:38:01TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4037819143Outbound2020-02-13 20:06:192020-02-13 20:38:30-
4037819143CallBack2020-02-13 20:45:122020-02-13 20:50:58TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4037819143Outbound2020-02-13 20:45:212020-02-13 20:49:49-
4163058294CallBack2020-02-13 16:36:592020-02-13 17:46:31TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4163058294Outbound2020-02-13 16:43:002020-02-13 16:43:07-
4163058294Outbound2020-02-13 17:06:362020-02-13 17:06:42-
4163058294CallBack2020-02-13 17:25:492020-02-13 17:39:23TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4163058294Outbound2020-02-13 17:26:122020-02-13 17:30:21-
4163058294Outbound2020-02-13 17:27:152020-02-13 17:27:22-
4185710361CallBack2020-02-13 18:28:512020-02-13 19:17:59TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4185710361Outbound2020-02-13 18:54:522020-02-13 18:54:55-
4185710361Outbound2020-02-13 19:17:372020-02-13 19:17:52-
4185710361CallBack2020-02-13 20:14:572020-02-13 20:15:48TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
4185710361Outbound2020-02-13 20:15:422020-02-13 20:15:53-
5149832646CallBack2020-02-13 16:23:342020-02-13 17:13:09TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
5149832646Outbound2020-02-13 16:24:162020-02-13 16:24:43-
5149832646CallBack2020-02-13 16:45:312020-02-13 16:47:50TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
5149832646Outbound2020-02-13 16:45:572020-02-13 16:58:45-
5149832646Outbound2020-02-13 16:46:542020-02-13 16:46:59-
5149871616CallBack2020-02-13 16:29:572020-02-13 17:36:47TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
5149871616Outbound2020-02-13 16:55:032020-02-13 16:55:10-
5149871616CallBack2020-02-13 17:36:002020-02-13 17:40:44TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
5149871616CallBack2020-02-13 19:14:542020-02-13 19:16:58TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
5149871616Outbound2020-02-13 19:16:192020-02-13 19:16:48-
5149871616CallBack2020-02-13 20:02:132020-02-13 20:10:39TerminatedDate(CallBack)-MAX(TerminatedDate(Outbound)
5149871616Outbound2020-02-13 20:02:162020-02-13 20:02:35-
Here is the Output that I would like to have:
Hi @ ,
I would like to do a GROUP BY RemoteID Column and then add  2 new columns Diff-TerminatedDate and Diff-ConnectedDate as below:
Here is my table Data sample synthesized:
The output will be as below:
RemoteIDMediaType_nameConnectedDateTerminatedDateDiff-TerminatedDateDiff-ConnectedDate
ImkeF
Hi @Anonymous
    #"Added Custom"
Hi @ImkeF ,
It matches perfectly my need.
thanks again.
Hi @ImkeF ,
Thank you for your reply, please forgive my bad explanantion :).
I will check that and try  to implement it to my code.I will let you know ASAP.
Thanks.
Hi everyone,
Could anyone help on this please ?
Much appreciated.
Thanks.
ImkeF
Hi @Anonymous
Sorry, misses your answer.
Will check it out in a sec.
ImkeF
 Hi @Anonymous
could you please check the data for the desired output?
I cannot see any calculation there. So its just a selection of the first 4 items with "MediaType" = "CallBack"
Please make sure that the desired input and output match each other completely.
Thanks ImkeF, much appreciated.
