need help in power bi
Hi power bi developers, please help me out
I have a columns like this in power bi - attachment given.
1.I have to keep a filter with higher members- only (XX123 ,XX124)- IF I SELECT THE ANY ONE IN FILTER IT SHOULD SHOW FROM HIGHER TO LOWER path with aggregation chart
I have to show the chart like this - chart snap attached below. OR ANY RECOMMENDED VISUALS IN POWER BI.
PLEASE HELP ME ! i'M NEW TO POWER BI
- sarath_chandra
Helper III
BA_Pete rubayatyasmin AlienSx slorin ronrsnfld please help me out
- rubayatyasmin
Hi, sarath_chandra thanks for reaching out.
There is hierarchy chart in Power BI(third party) that is used to represent organizational hierarchy.
- Refer to this tutorial: https://medium.com/@gulcekincrk/have-you-ever-wondered-how-to-create-an-organizational-hierarchy-in-power-bi-e4f2ad38d683
- Hierarchy chart
I hope this helps.
Thanks.
If I helped you in any way, why not give it a kudos! π
Did I help? accept it as a solution.
- sarath_chandra
Helper III
Thanks for input rubayatyasmin
but my data was like this - with multiple parent and child column values and level column plays a vital role here.please let me know how to standardised this data
how to create dynamically chart like below (desired output like below)
please help me out.Thanks a lot for your work!
- sarath_chandra
Helper III
FreemanZ please help me with your solutions
