how to: Direct Query hierarchical (two level) sql query into Power BI
I would like to know how I can direct query the sql code for the hierarchical (two level) sql query. I would like to import the sql code for the data output below to PowerBI, PLEASE NOTE I ALREADY KNOW HOW TO DIERCT QUERY A NORMAL SQL CODE INTO POWERBI SO I AM NOT LOOKING FOR INSTRUCTIONS ON THAT)
I have already tried by pressing 'Get Data' and selecting 'SQL Server' and it only shows data for the top level (1). If anyone could please help me figure out how I can direct query my sql code so that both levels show on Power BI, that would be much appreciated!
- v-juanli-msftCommunity Support
Hi OPS-MLTSD
Do you refer to hierarchical data in sql server?
You could expand the tables under Navigator.
Or you can write sql queries under Advanced Options->SQL statement.
Maggie
- OPS-MLTSDPost Patron
this is what I mean. How do I import the query to PBI?
as you can see from the picture I posted above, there are two levels of data. Level one (makred as 1 in red) and level two (marked as 2 in red). When I import the query like how I normally do by going into 'Get data' and selecting 'SQL Server' and following the procedure, I only get data for the top row (marked in red). I want to know, how can I get import the query from SQL to Power BI so that I can see all the data
