sathishramuk33
5 years agoFrequent Visitor
help with advanced power query
hi all , i create one query , in this query i fix to maxium date is today date, but now i need to add on next year date .so how to add on the 2022 year date in this query . my query is : ...
5 years agoNot applicable
sathishramuk33
With this overly long query, you should just post a sample pbix file instead of throwing all codes. I guess you can also explain your expected output, see if there is a another easier way to achieve it.
Paul Zheng _ Community Support Team
- sathishramuk335 years agoFrequent Visitor
i need this type of solution( dynamic header change based on today date) pl sort me out
