mrmick69's avatar
mrmick69
8 years ago
flow add rows to a Power BI dataset
Using Flow, I have created a flow to Get Rows from SQL Server table and add them to a PowerBI dataset. I followed all the steps and the flow runs, but when it gets to the step of adding rows to the Power BI dataset it takes a long time to run. This is a very small dataset (190 records), but it takes over three minutes for it to load. I played with all the setting I know to adjust, but can't improve the performance.
1 Reply
    mrmick69,
    How do you create the custom flow and which blog do you refer to when adding the rows to Power BI?
    Lydia
