Spotto
Helper IV
Helper IV
Write power bi data to a table with power apps (flow)
Hi everyone, I'm new to power apps and would like some help.
I have a table in power bi and I would like each update (power bi) of power apps through a flow to record the table data in another table. This table can be in sharepoint or sql and will always be a single table adding the records in the same table at each update.
thank you for the help
v-yalanwu-msft
