The problem is that there are 2 depots with various sizes of buckets. They have some prefill volume of water.
I have different water allotment of these 2 depots.
The volume utilisation is defined as the amount of water in the bucket divided by the volume of bucket. The goal is to maximise the volume utilised of each bucket given the constraint of water allotment for 2 depots
Here is the input file for bucketID with relationship to DepotID: DepotID BucketID Volumeofbucket PrefillValue Volumeutilised Depot 1 Bucket 1 100 50 50% Depot 1 Bucket 2 1000 600 60% Depot 1 Bucket 3 100 20 20% Depot 1 Bucket 4 10 9 90% Depot 1 Bucket 5 10000 9000 90% Depot 1 Bucket 6 1000 300 30% Depot 1 Bucket 7 100 40 40% Depot 2 Bucket 1 200 55 28% Depot 2 Bucket 2 400 222 56% Depot 2 Bucket 3 50 11 22% Depot 2 Bucket 4 4000 600 15%
This is Depot alloted water values: DepotID AllotedWater Depot 1 900 Depot 2 400
This is the output for Depot1. I will need the output for Depot2 also in the same sheet. Bucket ID Volume of bucket Prefill Value Extra fill from Alloted volume After Fill Volume Volume utilised Bucket 1 100 50 30 80 80% Bucket 2 1000 600 200 800 80% Bucket 3 100 20 60 80 80% Bucket 4 10 9 9 90% Bucket 5 10000 9000 9000 90% Bucket 6 1000 300 500 800 80% Bucket 7 100 40 40 80 80%
e.g. a bucket (call it bucket A) lowest utilisation is at 20%. The bucket with 20% utilisation will be filled first. lets say the next lowest utilisation of bucket (call it bucket B)is at 35%. Then once the bucket A's utilisation is at 35% then bucket A & bucket B will be filled simultaneously till next bucket utilisation is not achieved say Bucket C with 40% utilisation. Then all 3 will be filled, so and so forth till all are 100% or alloted water gets exhausted
Here is an adjusted version that "works" for both depots
One way to tackle the sequential issue would be to allocate one unit at a time (let's assume you are talking about cubic yards or something). That would create many more steps (900 steps for Depot 1, for example) but would fill the buckets more evenly.
Another Option:
Your Depot table:
| DepotID | BucketID | Volumeofbucket | PrefillValue |
| Depot 1 | Bucket 1 | 100 | 50 |
| Depot 1 | Bucket 2 | 1000 | 600 |
| Depot 1 | Bucket 3 | 100 | 20 |
| Depot 1 | Bucket 4 | 10 | 9 |
| Depot 1 | Bucket 5 | 10000 | 9000 |
| Depot 1 | Bucket 6 | 1000 | 300 |
| Depot 1 | Bucket 7 | 100 | 40 |
| Depot 2 | Bucket 1 | 200 | 55 |
| Depot 2 | Bucket 2 | 400 | 222 |
| Depot 2 | Bucket 3 | 50 | 11 |
| Depot 2 | Bucket 4 | 4000 | 600 |
Your Allocation Table:
| DepotID | Alloted Water |
| Depot 1 | 900 |
| Depot 2 | 400 |
Custom Function
Rename as noted in the comments
//Rename this query: fnFilterNonAdds
Source = (tbl as table, wtr as number)=>
[a=tbl,
b=List.Sum(a[Volumeofbucket]),
c=List.Sum(a[PrefillValue]),
d=List.Min({1,(c+wtr)/b}),
e=Table.SelectRows(a,each [PrefillValue] / [Volumeofbucket] < d),
f=if Table.RowCount(e) < Table.RowCount(a) then fnFilterNonAdds(e,wtr)
else Table.AddColumn(e,"Percent",each d)
][f]
Source
Main Code body
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WckktyC9RMFTSUXIqTc5OhTANDQyApKmBUqwOFhVGEBUgJWYGONQYw00xwqHCBKwCSFhilzeF2gJWYoDLHjOEW4xxqTGHu8UEWYURqp+NIH42xa7CCKwb7B8jI+xKjCFBBrTLELsCE4gZ8HCLBQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [DepotID = _t, BucketID = _t, Volumeofbucket = _t, PrefillValue = _t]),
{"DepotID", type text}, {"BucketID", type text}, {"Volumeofbucket", Int64.Type}, {"PrefillValue", Int64.Type}}),
#"Grouped Rows" = Table.Group(#"Changed Type", {"DepotID"}, {
{"Fill Buckets", (t)=>
[a=Table.SelectRows(#"Allocation", each [DepotID]=t[DepotID]{0})[Alloted Water]{0},
b=fnFilterNonAdds(t,a),
c=Table.AddColumn(b, "FilledBucket", each [Volumeofbucket]*[Percent]),
d=Table.AddColumn(c,"AmtToAdd", each [FilledBucket]-[PrefillValue])
][d]
, type table [DepotID=nullable text, BucketID=nullable text, Volumeofbucket=nullable number,
PrefillValue=nullable number, Percent=Percentage.Type,
FilledBucket=nullable number, AmtToAdd=nullable number]
#"Expanded Fill Buckets" = Table.ExpandTableColumn(#"Grouped Rows", "Fill Buckets",
{"BucketID", "Volumeofbucket", "PrefillValue", "Percent", "FilledBucket", "AmtToAdd"}),
#"Combine with zero fill" =
[a=Table.NestedJoin(#"Expanded Fill Buckets",{"DepotID","BucketID"},
#"Changed Type",{"DepotID","BucketID"},
"Join", JoinKind.RightAnti),
b = Table.SelectColumns(a,{"Join"}),
c=Table.ExpandTableColumn(b,"Join",{"DepotID","BucketID","Volumeofbucket","PrefillValue"}),
d=Table.Combine({#"Expanded Fill Buckets",c})
][d],
//We don't need all the columns listed, but they were there for proofing the results
#"Sorted Rows" = Table.Sort(#"Combine with zero fill",{{"DepotID", Order.Ascending}, {"BucketID", Order.Ascending}}),
#"Total nonFilled" = Table.ReplaceValue(
#"Sorted Rows",
each [FilledBucket],
each [PrefillValue],
(x,y,z) as number=>if y=null then z else x,
{"FilledBucket"}),
#"Add Percent" = Table.AddColumn(#"Total nonFilled", "Percent Filled", each [FilledBucket] / [Volumeofbucket], Percentage.Type),
#"Removed Columns" = Table.RemoveColumns(#"Add Percent",{"Percent"})
#"Removed Columns"
Results in PQ:
There are extra columns in the results table for "proofing" but I think this is what you want.
Note that I did not include your initial volume utilization as it is not needed for the calculation.
Some of the column names are different as I initially answered this question on the stackoverflow forum and you had slightly different naming there in your example, but you should be able to edit the code as needed.
fx_spill = (tbl as table) =>
spill_volume = alloted_water{[DepotID = tbl{0}[DepotID]]}[Alloted Water],
rows = List.Buffer(Table.ToList(Table.Sort(tbl, {"Volumeutilized"}), (x) => x)),
gen = List.Generate(
() => [i = 0, vol = rows{0}{2}, filled = rows{0}{3}, pct = (filled + spill_volume) / vol],
(x) => x[i] < List.Count(rows) and rows{x[i]}{4} < x[pct],
(x) => [i = x[i] + 1, vol = x[vol] + rows{i}{2}, filled = x[filled] + rows{i}{3}, pct = (filled + spill_volume) / vol],
(x) => x[[i]] & (if x[pct] >= 1 then [pct = 1] else [pct = x[pct]])
last = List.Last(gen),
spilled = List.Transform(
List.Positions(rows),
(x) => ((r) => r & (if last = null or x > last[i] then {0, r{4}} else {r{2} * last[pct] - r{3}, last[pct]}))(rows{x})
][spilled],
input_file = Excel.CurrentWorkbook(){[Name="input_file"]}[Content],
alloted_water = Excel.CurrentWorkbook(){[Name="alloted_water"]}[Content],
group = Table.Group(input_file, "DepotID", {"x", fx_spill}),
result = Table.FromList(List.Combine(group[x]), (x) => x, Table.ColumnNames(input_file) & {"filled amount", "filled pct"})
result
Hi @ABCS ,
As we have not received a response from you yet, I would like to confirm whether you have successfully resolved the issue or if you require further assistance. If the issue has been resolved, please mark the helpful reply as a "solution" to indicate that the question has been answered and to assist others in the community.
Thank you for your cooperation. Have a great day.
Hi @ABCS ,
Has the issue been resolved on your end? If so, please share your solution and mark it as "Accept as Solution." This will assist others in the community who are dealing with similar problems and help them find a solution more quickly.
Hi @ABCS ,
Thank you @AlienSx , @ronrsnfld and @lbendlin for the helpful repsonse!
I wanted to check in on your situation regarding the issue. Have you resolved it? If you have, please consider marking the reply that helped you or sharing your solution. It would be greatly appreciated by others in the community who may have the same question.
][spilled],
result
Another Option:
Your Depot table:
| Depot 1 | 900 |
| Depot 2 | 400 |
Custom Function
[a=tbl,
][f]
Source
Main Code body
][d]
][d],
#"Sorted Rows",
{"FilledBucket"}),
#"Removed Columns"
Results in PQ:
Thanks for the reply.
It seems to work for Depot 1. It has one problem:
| DepotID | BucketID | Volumeofbucket | PrefillValue | CurrentValue | Step | VolumeUtilised |
| Depot 1 | Bucket 4 | 10 | 9 | 9 | 0 | 90% |
| Depot 1 | Bucket 4 | 10 | 9 | 9 | 14 | 90% |
| Depot 1 | Bucket 3 | 100 | 20 | 20 | 0 | 20% |
| Depot 1 | Bucket 3 | 100 | 20 | 90 | 14 | 90% |
| Depot 1 | Bucket 7 | 100 | 40 | 40 | 0 | 40% |
| Depot 1 | Bucket 7 | 100 | 40 | 90 | 14 | 90% |
| Depot 1 | Bucket 1 | 100 | 50 | 50 | 0 | 50% |
| Depot 1 | Bucket 1 | 100 | 50 | 90 | 14 | 90% |
| Depot 1 | Bucket 6 | 1000 | 300 | 300 | 0 | 30% |
| Depot 1 | Bucket 6 | 1000 | 300 | 900 | 14 | 90% |
| Depot 1 | Bucket 2 | 1000 | 600 | 600 | 0 | 60% |
| Depot 1 | Bucket 2 | 1000 | 600 | 600 | 14 | 60% |
| Depot 1 | Bucket 5 | 10000 | 9000 | 9000 | 0 | 90% |
| Depot 1 | Bucket 5 | 10000 | 9000 | 9000 | 14 | 90% |
It leaves the bucket 2 at 60& while bucket 6 is filled till 90%.
Ideally, it should have distributed an equal %ages to both as the available water is limited.
Also, how do I copy it across all depots.
As I mentioned before I am not aware of a way to fill them in parallel. Power Query M is a sequential (streaming) language. One at a time.
As you can see Bucket 2 is pulling the short straw as the remaining allotment is insufficient to bring it up to 90% in step 15
Here is the pbix again - the posted code was just a first rough draft.
Here is the result when adding one "unit" at a time.
Here is an alternative approximative approach that does only require two iterations.
1. eliminate all buckets that are above the average of (Prefill Value + Allotment ) / Total Volume (since they cannot be "filled lower").
2. For the remaining buckets calculate the average of (Prefill Value + Allotment ) / Total Volume again
3. For each bucket calculate (<the value from #2>-[PrefillValue]/[Volumeofbucket])*[Volumeofbucket] + [PrefillValue])
That will get all "lesser" buckets filled to the same level, plus/minus a rounding error. In the case of Depot1 this would fill all buckets except 4 and 5 to 83% (4 and 5 are already at 90%).
Would that be an acceptable approach?
Do you want just the final result or do you want an animation of the allotment process?
If a smaller and a larger bucket have the same lowest percentage, which one should be filled first?
I think this is beyond the capabilities of Power Query. Has to be done sequentially because you need to be able to tell when the allotment runs out.
Here is a first draft that seems to get the result you want for Depot1
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Volumeofbucket", Int64.Type}, {"PrefillValue", Int64.Type}}),
#"Added Custom3" = Table.AddColumn(#"Changed Type", "CurrentValue", each [PrefillValue]),
#"Added Custom" = Table.AddColumn(#"Added Custom3", "Step", each 0),
#"Filtered Rows" = Table.SelectRows(#"Added Custom", each ([DepotID] = "Depot 1")),
NextLevel = (tbl)=>
#"Added Custom" = Table.AddColumn(Table.Buffer(tbl), "Percent", each [CurrentValue]/[Volumeofbucket],Percentage.Type),
#"Sorted Rows" = Table.Sort(#"Added Custom",{{"Percent", Order.Ascending},{"Volumeofbucket", Order.Ascending}}),
#"Added Index" = Table.AddIndexColumn(#"Sorted Rows", "Index", 0, 1, Int64.Type),
#"Added Custom1" = Table.AddColumn(#"Added Index", "NextHighest Percent", (k)=> List.Min(Table.SelectRows(#"Added Index",each [Percent]>k[Percent])[Percent]) ?? 1,Percentage.Type),
#"Added Custom2" = Table.AddColumn(#"Added Custom1", "Delta", each if [Index]=0 then [Volumeofbucket]*([NextHighest Percent]-[Percent]) else 0,Int64.Type),
#"Replaced Value" = Table.ReplaceValue(#"Added Custom2",each [CurrentValue],each [CurrentValue]+[Delta] ,Replacer.ReplaceValue,{"CurrentValue"}),
#"Replaced Value2" = Table.ReplaceValue(#"Replaced Value",each [Step],each [Step]+1 ,Replacer.ReplaceValue,{"Step"}),
#"Removed Columns" = Table.RemoveColumns(#"Replaced Value2",{"Index", "Percent", "NextHighest Percent", "Delta"})
#"Removed Columns",
Levels = List.Generate(
() => #"Filtered Rows",
each List.Sum(_[CurrentValue])<900+List.Sum(#"Filtered Rows"[PrefillValue]),
each NextLevel(_)
#"Converted to Table" = Table.FromList(Levels, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
#"Expanded Column1" = Table.ExpandTableColumn(#"Converted to Table", "Column1", {"DepotID", "BucketID", "Volumeofbucket", "PrefillValue", "CurrentValue", "Step"}, {"DepotID", "BucketID", "Volumeofbucket", "PrefillValue", "CurrentValue", "Step"})
#"Expanded Column1"
| 11 | |
| 10 | |
| 5 | |
| 4 |
| 26 | |
| 17 | |
| 13 | |
| 10 | |
| 10 |
