Zakros
2 years agoRegular Visitor
Use Power Query Editor Instead dax Column = MAX and AllExcept
Hi, I'm a beginner in Power BI & Power Query and I don't manage to do something in Power Query Editor. In my table "Base DS-Azure" I need to create a new colmun which input the text "Max" on ...
- 2 years ago
Here is my solution here
Table Name: My Solution
If the post helps please give a thumbs up
If it solves your issue, please accept it as the solution to help the other members find it more quickly.
Tharun
tharunkumarRTK
2 years agoSuper User
Zakros
Can you share the pbix file with sample data and desired output?
- Zakros2 years agoRegular Visitor
- tharunkumarRTK2 years agoSuper User
Tharun
- ronrsnfld2 years agoSuper User
Unless you need it for some other purpose, the DS & Mail column is not needed for this Power Query M Code solution:
let //Change Source line to your actual line Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content], #"Changed Type" = Table.TransformColumnTypes(Source,{{"DS-Name", type text}, {"DS-Autorization Type ", type text}, {"DS-Autorization Level", Int64.Type}, {"Mail", type text}}), //add index column to preserve original order #"Added Index" = Table.AddIndexColumn(#"Changed Type", "Index", 0, 1, Int64.Type), //Group by DS-Name and Mail //then add column for the MAX #"Grouped Rows" = Table.Group(#"Added Index", {"DS-Name", "Mail"}, { {"MAX", (t)=> Table.AddColumn(t, "Max Level", each if [#"DS-Autorization Level"] = List.Max(t[#"DS-Autorization Level"]) then "MAX" else null), type table [#"DS-Name"=nullable text, #"DS-Autorization Type "=nullable text, #"DS-Autorization Level"=nullable number, Mail=nullable text, Index=number, Max Level = nullable text]}}), #"Removed Columns" = Table.RemoveColumns(#"Grouped Rows",{"DS-Name", "Mail"}), #"Expanded Max" = Table.ExpandTableColumn(#"Removed Columns", "MAX", {"DS-Name", "DS-Autorization Type ", "DS-Autorization Level", "Mail", "Index", "Max Level"}), #"Sorted Rows" = Table.Sort(#"Expanded Max",{{"Index", Order.Ascending}}), #"Removed Columns1" = Table.RemoveColumns(#"Sorted Rows",{"Index"}) in #"Removed Columns1"Results from your data
