Is it possible to start the power query sdk through command line?
Hi @Anonymous ,
Currently as far as I know, it is not supported to run power query sdk via CMD directly.
Potential workaround is that you may try to use PowerQueryNet which allows run power query as a medium to combine.
You can refer: PowerQueryNet
