Searching for Semantic Model in Excel Connection to Power BI Not Working
- 1 year ago
Hi cconnolly , Thank you for reaching out to the Microsoft Community Forum.
Check for conflicting add-ins. Disable all non-essential add-ins and restart Excel. If the issue is resolved, re-enable add-ins one by one to identify the cause. Repair Microsoft Office (Control Panel -> Programs & Features -> Microsoft Office -> Change -> Repair) and restart your computer after the repair completes. Windows 11 can cause issues with UI elements, so adjust Display Scaling to 100% or 125%.
If none of these steps work, the best next step is to report the issue to Microsoft Support, as it may be a bug or a backend issue. Provide them with all the troubleshooting steps you've already taken to help them understand the issue better and provide a solution.
Below is the link to create Microsoft Support ticket:
How to create a Fabric and Power BI Support ticket - Power BI | Microsoft LearnFor a temporary workaround, try opening an Existing PivotTable and Reconnect.
If this helped solve the issue, please consider marking it 'Accept as Solution' so others with similar queries may find it more easily. If not, please share the details, always happy to help.
Hi cconnolly Could you ensure both applications are updated to the latest versions to address potential bugs and please clear the cache in excel by cheking this
Go to File > Options > Trust Center > Trust Center Settings.
Clear cached data under Privacy Options or restart Excel with a fresh cache.
Yes, I tried both of those but they haven't worked for me unfortunately.
