PijushRoy's avatar
PijushRoy
5 years ago
Require Help to Move Column Value to Column header in POWER QUERY
I have below mentioned data and I need to move the 1st column value to column header.
ParameterMeasure
Length3x35 SQMM
Length3x50 SQMM
Length3x70 SQMM
Length3x95 SQMM
Length3x120 SQMM
Length3x150 SQMM
Length3x185 SQMM
Length3x240 SQMM
Length3x300 SQMM
Length3x400 SQMM
Rated Frequency50 Hz
Voltage Grade6.35/11
I need to prepared my data following way.
LengthRated FrequencyVoltage Grade
3x35 SQMM50 Hz6.35/11
3x50 SQMM50 Hz6.35/11
3x70 SQMM50 Hz6.35/11
3x95 SQMM50 Hz6.35/11
3x120 SQMM50 Hz6.35/11
3x150 SQMM50 Hz6.35/11
3x185 SQMM50 Hz6.35/11
3x240 SQMM50 Hz6.35/11
3x300 SQMM50 Hz6.35/11
3x400 SQMM50 Hz6.35/11
How I can management this, I already try to solve this by PIVOT option.
Your support is highly appreciated.
  • Hello PijushRoy
    you can apply some Table.Group by grouping by parameter and create a list from the measure column. In the second step a Table.FromColumns is used to us the data from the grouping-step to create your new table
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8knNSy/JUNJRMq4wNlUIDvT1VYrVQRE2NcAqbI5d2BK7IYZG2JUb4jDd0AK7OUYm2NUbG2AXN0EWD0osSU1RcCtKLSxNzUuuBCoA2u5RNeLlwvJzShLTUxXcixJTUoEyZnrGpvqGhiNbLhYA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Parameter = _t, Measure = _t]),
        ChangeType = Table.TransformColumnTypes(Source,{{"Parameter", type text}, {"Measure", type text}}),
        GroupYourData = Table.Group(ChangeType, {"Parameter"}, {{"Measures", each _[Measure], type table [Parameter=text, Measure=text]}}),
        CreateYourTable= Table.FromColumns
            GroupYourData[Measures],
            GroupYourData[Parameter]
        CreateYourTable
    Copy paste this code to the advanced editor in a new blank query to see how the solution works.
    Kudoes are nice too
    Have fun
    Jimmy
    Hi PijushRoy ,
    Go To Transform tab and select the first column and then do a Transpose.
    That would solve your problem.
    Appreciate your kudos!!! Please mark my post as solution if this helps you.
    • PijushRoy's avatar
      PijushRoy
      Ilalready try and get the result as below snap
      but I require below format
  • Jimmy801's avatar
    Jimmy801
    Hello PijushRoy
        CreateYourTable
    Kudoes are nice too
    Have fun
    Jimmy
      PijushRoy
      Hi
      It is working find, Thanks a lots.
      Please suggest, How you implement this logic, so I can learn.
      • Jimmy801's avatar
        Jimmy801
        Hello PijushRoy
        then I would ask you to mark it as solution.
        The best way to understand M-code to go to the microsoft power query homepage and check out the functions I used, and try to analyse what exactly does.
        Kudoes are nice too
        Have fun
        Jimmy
    Hi @PijushRoy
    Here is another way just for your reference.
        res = let a=Table.ToColumns(Source),
                  b=List.Distinct(a{0})
                  Table.FromColumns(List.Split(a{1},List.Count(a{0})/List.Count(b)),b)
        res
    Logic is:
    1. Split source table to two columns, the first is header name column and the second is data column.
    2. List.Distinct(first column) get the unique header names.
    3. List.Split(second column, pagesize=the count of table rows/the count of header names).
