PijushRoy
6 years agoRequire Help to Move Column Value to Column header in POWER QUERY
Hi, I have below mentioned data and I need to move the 1st column value to column header. Parameter Measure Length 3x35 SQMM Length 3x50 SQMM Length 3x70 SQMM Length 3x95 SQMM ...
- 6 years ago
Hello PijushRoy
you can apply some Table.Group by grouping by parameter and create a list from the measure column. In the second step a Table.FromColumns is used to us the data from the grouping-step to create your new table
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8knNSy/JUNJRMq4wNlUIDvT1VYrVQRE2NcAqbI5d2BK7IYZG2JUb4jDd0AK7OUYm2NUbG2AXN0EWD0osSU1RcCtKLSxNzUuuBCoA2u5RNeLlwvJzShLTUxXcixJTUoEyZnrGpvqGhiNbLhYA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Parameter = _t, Measure = _t]), ChangeType = Table.TransformColumnTypes(Source,{{"Parameter", type text}, {"Measure", type text}}), GroupYourData = Table.Group(ChangeType, {"Parameter"}, {{"Measures", each _[Measure], type table [Parameter=text, Measure=text]}}), CreateYourTable= Table.FromColumns ( GroupYourData[Measures], GroupYourData[Parameter] ) in CreateYourTableCopy paste this code to the advanced editor in a new blank query to see how the solution works.
Kudoes are nice too
Have fun
Jimmy
shaowu459
Resolver II
6 years ago
Hi @PijushRoy
Here is another way just for your reference.
res = let a=Table.ToColumns(Source),
b=List.Distinct(a{0})
Table.FromColumns(List.Split(a{1},List.Count(a{0})/List.Count(b)),b)
resLogic is:
- Split source table to two columns, the first is header name column and the second is data column.
- List.Distinct(first column) get the unique header names.
- List.Split(second column, pagesize=the count of table rows/the count of header names).
