Problems with connecting against Azure Spark on HDInsight
Thanks for taking some time and trying to help me.
I login with the regular username and password that is registered through Spark on Azure (the admin user I use to access anything with spark).
It can be good to know have been following this guide: https://azure.microsoft.com/sv-se/documentation/articles/hdinsight-apache-spark-use-bi-tools/ and im stuck at Step4 in the title "Use Power BI to analyze data in the Hive table"
A year later and I'm running into this issue, too! There seems to be some nuance that I'm missing about connecting to the cluster - although our authentication is set up to be a basic username and password. And we have no ports blocked to the cluster. What a headache!
- AustinT9 years agoNew Member
I'm embarassed to say the "Gateway" issue is caused by disabling the Thrift servers in our cluster. We did this because our primary use cases are PySpark in nature and therefore do not require Thrift services. Re-enabling the Thrift server facilitates connection of PBI to the Spark cluster.
