Simon_29's avatar
Simon_29
5 years ago
Power query has a problem with decimal places under conditions
I have a problem that under the condition in Power Query, which I highlighted in yellow, the column called "Check 70% Margin" gives an incorrect output in the form of "no" as can be seen in the picture. In the first line (when I count integers) it throws the correct output, but in decimal numbers (the second line) it gives the output as "no" and there is a correct result.
Has anyone already had a similar problem that you could refer me to him?
Thank you very much for your help.
    5 years ago
    Hi Simon_29
    You can use Number.Round:
    Number.Round( [Column2]/[Column1],1)=0.7
    Hi Simon_29
    • Simon_29's avatar
      Simon_29
      Hi Vera:)
      Your solution worked. I had never thought of such a possibility before.
      Thank you very much:)
  • FarhanAhmed's avatar
    FarhanAhmed
    Your column Submitted TCV has an unassigned data type. change the type to decimal for both Submitted columns and check your results.
    • Simon_29's avatar
      Simon_29
      I've tried this before and it didn't work. However, Vera33 below in this post gave the right solution and it already works.
      Thank you very much 🙂
