Power query - Number.round function works in Power BI Desktop, not in Power BI Services
I use the function Number.Round in Power query. It works fine when used from Power BI Desktop
But when I try to refresh the report in Power BI Services (embedded licence), I get the following error :
Data source errorDataSource.Error: PostgreSQL : 42883: function round(double precision, integer) does not exist. DataSourceKind = PostgreSQL. DataSourcePath = ************. Message = 42883: function round(double precision, integer) does not exist. ErrorCode = -2147467259</pii>. . The exception was raised by the IDbCommand interface. Table: rejets
Here is my power query :
let Source = PostgreSQL.Database("*******************),
technique_job_reject = Source{[Schema="technique",Item="job_reject"]}[Data],
#"Filtered Rows1" = Table.SelectRows(technique_job_reject, each true),
#"Added Custom" = Table.AddColumn(#"Filtered Rows1", "Rounded RejectTime", each Number.Round(Number.From([reject_time])*24*60*60,0)/(24*60*60)),
#"Changed Type" = Table.TransformColumnTypes(#"Added Custom",{{"Rounded RejectTime", type datetime}}),
#"Removed Columns" = Table.RemoveColumns(#"Changed Type",{"reject_time"}),
#"Renamed Columns" = Table.RenameColumns(#"Removed Columns",{{"Rounded RejectTime", "Date rejet"}})
in #"Renamed Columns"
Can someone help me ?
Hi SGuichon ,
When I tested with the same query like yours, I got the same error in Power Query Editor:
Try to edit this query when adding the custom column:
#"Added Custom" = Table.AddColumn(#"Filtered Rows1", "Rounded RejectTime", each Number.Round(Number.From([reject_time])*24*60*60)/(24*60*60)),It should work:
- v-yingjl
Hi SGuichon ,
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly. - SGuichonFrequent Visitor
