Power Query under Power BI desktop create/add column for count of grouping
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("fdBLDoMwDATQu2RNpXGM48xZEPe/BomhlLaE3ShP8W9ZEkmBpykpIMTckrwyMtI6HVraW2Ytphwqxfznr1iVqBfK/Kja00dVXQR7X2GxR+0T6EiltuSXvnADT+2pfmnRmIVO85gZQ9Z/Pmu/WW9X7hznmu9v3diuvG4=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Asset No" = _t, #"Work Order" = _t, WeekYear = _t]),
#"Grouped Rows" = Table.Group(Source, {"Asset No", "WeekYear"}, {{"WOs / Week", each Table.RowCount(_), Int64.Type}, {"Rows", each _, type table [Asset No=nullable text, Work Order=nullable text, WeekYear=nullable text]}}),
#"Expanded Rows" = Table.ExpandTableColumn(#"Grouped Rows", "Rows", {"Work Order"}, {"Work Order"}),
#"Reordered Columns" = Table.ReorderColumns(#"Expanded Rows",{"Asset No", "Work Order", "WeekYear", "WOs / Week"}),
#"Added Custom" = Table.AddColumn(#"Reordered Columns", "Flag", each if [#"WOs / Week"]=1 then "One Work Order" else "Multi Work Order")
#"Added Custom"
How to use this code: Create a new Blank Query. Click on "Advanced Editor". Replace the code in the window with the code provided here. Click "Done". Once you examined the code, replace the Source step with your own source.
- KBD1 year ago
Helper III
Ibendlin:
Thanks for your responce. I believe I have a solution that takes me as far as the row count column.
As follows:
Source = Excel.Workbook(File.Contents("C:\Users\ne098406\OneDrive - New York Power Authority\dev\FleetManagement\PowerBI\Data\NYPA Fleet Analytics Dashboard.twb Files\Maint Data Extract.xlsx"), null, true),
#"Maint Data Extract_Sheet" = Source{[Item="Maint Data Extract",Kind="Sheet"]}[Data],
#"Promoted Headers" = Table.PromoteHeaders(#"Maint Data Extract_Sheet", [PromoteAllScalars=true]),
#"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers",{{"Asset number", type text}}),
weekOfYearStart = Table.AddColumn(#"Changed Type", "weekOfYearStart", each Date.WeekOfYear([Start date] )),
yearStart = Table.AddColumn(weekOfYearStart, "yearStart", each Date.Year( [Start date] )),
yearWeekStart = Table.AddColumn(yearStart, "yearWeekStartDate", each Number.ToText( [yearStart], "D4" ) & "-" & Number.ToText( [weekOfYearStart], "D2" )),
#"Added Custom" = Table.AddColumn(yearWeekStart, "Custom", each Table.Group(yearWeekStart, {"Asset number", "yearWeekStartDate"}, {{"AssetWeek_WO_Count", each Table.RowCount(_), Int64.Type}})),
AssetWeek_WO_cnt = #"Added Custom"{0}[Custom]
AssetWeek_WO_cntProblem:
How do I join Asset Number, yearWeekStartDate & AssetWeek_WO_Count back to the WorkOrder table? It would be a join on Asset Number & yearWeekStartDate?
Thanks for your kind assistance
KBD
- lbendlin1 year ago
Avoid joins in Power Query if possible. Let the Power BI data model do the work for you.
