Hello everyone! I mainly use Power Query in Power BI and recently in Excel. I noticed some differences between these two "versions" of Power Query (in the M language, for instance). It looks similar to what vpatel55 is experiencing in his post. Recently, I noticed a blocking difference: in PQry for PBI, I can access all the files of a SharePoint site library. If I do the same operation with PQry in Excel, some folders are invisible and inaccessible even though sub-folders of those invisible folders are visible. Have you ever had this experience? Do you know the cause and solution to this weirdness? Thanks for your help!
1 Reply
- MattAllingtonCommunity Champion
You should not post the same question on 2 different forums. It is disrespectful to those who answer questions, only to find out that you have already got the answer somewhere else.
