5 years agoNot applicable
Power Query / Power pivot countifs from multiple tables
I have 2 tables with a bunch of data, corresponding in two columns with Attribute1 and date. I'd like to create a table that: - has two columns with the unique combinations of Date and Atrribute...
ziying35
5 years agoImpactful Individual
Hi, Anonymous
Try this:
// fx
(tbl_name)=>
Source = Excel.CurrentWorkbook(){[Name=tbl_name]}[Content],
group = Table.Group(Source, {"Date", "Attribute"}, {{"Count_"&Text.Select(tbl_name, {"0".."9"}), each Table.RowCount(_), Int64.Type}})
group
// output
Source = List.Transform({"Table_1", "Table_2"}, fx),
fnTrans = (tbl)=>
Record.Combine(
List.Transform(
List.Skip(Table.ColumnNames(tbl),2),
each Record.FromList(
{List.Last(List.RemoveNulls(Table.Column(tbl, _)), null)},
{_}
tblCmb = Table.Combine(Source),
group = Table.Group(tblCmb, {"Date", "Attribute"}, {"t", fnTrans}),
expd = Table.ExpandRecordColumn(group, "t", {"Count_1", "Count_2"}),
sort = Table.Sort(expd,{{"Date", Order.Ascending}}),
chType = Table.TransformColumnTypes(sort,{{"Date", type date}})
chType
Paste my two query codes directly into the Power Query editor of the Excel file you provided as an example, and follow the screenshot below:
If you want the date to be displayed as in the example you provided, it is recommended to set it in the Excel worksheet by Format Cells.
Thank you for the reply! I need to take some time to properly go through it and understand it though.
- Jimmy8015 years agoCommunity Champion
Hello Anonymous
good luck. Waiting for your feedback then
BR
Jimmy
