Power Query / Power pivot countifs from multiple tables
Hello Anonymous
check out this solution. Should be a bit easier to understand. Be aware that it contains also two datasets of tables. Also in order that everyone can try it. Just substitute theses datasets with your Excel-tables
Table1 =
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjDUMzDSMzJQ0lFyUorVAQoYoQsYwwUcIQIm6AKm6AJmcAFnpdhYAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Date = _t, Atribute = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Date", type date, "de-DE"}, {"Atribute", type text}})
#"Changed Type",
Table2 =
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjDUMzDSMzJQ0lFyUorVAQoYwQVc0AWIVmGMLBALAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Date = _t, Atribute = _t]),
#"Changed Type",
CombineAndDistinct = Table.Distinct(Table.Combine({Table1,Table2})),
AddCountForTable1 = Table.AddColumn
CombineAndDistinct,
"Count Table1",
(addrec)=> Table.RowCount(Table.SelectRows(Table1, each Record.SelectFields(_, {"Date", "Atribute"}) = Record.SelectFields(addrec, {"Date", "Atribute"}) ))
AddCountForTable2 = Table.AddColumn
AddCountForTable1,
"Count Table2",
(addrec)=> Table.RowCount(Table.SelectRows(Table2, each Record.SelectFields(_, {"Date", "Atribute"}) = Record.SelectFields(addrec, {"Date", "Atribute"}) ))
AddCountForTable2
Copy paste this code to the advanced editor in a new blank query to see how the solution works.
Kudoes are nice too
Have fun
Jimmy
- Anonymous5 years agoNot applicable
Thank you for the reply!
What I ended up doing was starting a blank query and basically doing source = table1 & table2 & table3 etc., and going from there.
Am I correct in understanding your code basically does the same? Is there a speed difference when refreshing the query?
Because I've discovered I can build most of the (what would probably considerd rather rudimentary) tables I need with the Power Query GUI, but it is speed that is severely bottlenecking me now. As a result of several query merges, and then referencing these queries ~20 times to make ~20 small grouped by tables in a simple dashboard, I'm finding that excel seems to recalculate the referenced query every time before it does a new group by (if that makes any sense), allowing me to go for a walk for ~10 mins.
