5 years agoNot applicable
Power Query / Power pivot countifs from multiple tables
I have 2 tables with a bunch of data, corresponding in two columns with Attribute1 and date. I'd like to create a table that: - has two columns with the unique combinations of Date and Atrribute...
artemus
5 years agoMicrosoft Employee
You would add this as a custom column to your table which has distinct date/attribute.
For attribute, simply replace [Date] with [Attribute] when you add another column.
artemus
If your looking for just the count of the combinations then, all you need to do, is apply a Group by on the main table, selecting both the Date and Attribute columns.
- Anonymous5 years agoNot applicable
No I am looking for a table that has counts for unique dat/attribute combo's from two other tables. Pls let me know what is not clear about the screenshot I posted in the opening post, with the intended end result. Thank you! 🙂
