Power Query OData Top and Filter not working ?
- 1 year ago
Hi Watever,
Thank you for reaching out.
We understand you're trying to get a filtered and limited set of items from your SharePoint list using Power Query, but the $filter, $orderby, and $top options aren't working as expected with OData.Feed. This is a known issue, as Power Query doesn't always apply these options properly due to the way it manages metadata and query folding.
Since your direct web URL works, we suggest using the Web.Contents() function instead. This approach gives you full control over the request and ensures the query parameters are used as intended.
Here’s how you can set up your Power Query with Web.Contents:
url = "https://tenant.sharepoint.com/sites/SharepointName/_api/web/Lists/GetByTitle('List_Name')/Items?$filter=Receiving_Site eq 'ABCD'&$orderby=Id desc&$top=2",
Source = Json.Document(Web.Contents(url)),
Items = Source[value]
Items
This method should provide the filtered and sorted results you expect. If your dataset is large, make sure your SharePoint list is properly indexed, and check your authentication settings in Excel if you encounter any access issues.
Hi Watever,
We wanted to follow up since we haven't heard back from you regarding our last response. We hope your issue has been resolved.
Thank you for being a valued member of the Microsoft Fabric Community Forum!
Hi Watever,
I wanted to check in your situation regarding the issue. Have you resolved it? Should you have any further questions, feel free to reach out.
Thank you for being a part of the Microsoft Fabric Community Forum
- v-sgandrathi1 year ago
Hi Watever,
If you need any further assistance, feel free to reach out.
